JPortici, congratz on the score !
Anyway, this should be correct, right? Shematic says bridge between 2 and 3 instead of 1 to 2 and 3 to 4
Though I don't remember the detail now, I did the rewiring from 110V to 230V "exactly" as the manual instructed, of course, check, recheck ... and recheck again, and it just work.
- do i need to connect the earth terminal? I don't have an US to IT/SHUCKO adapter with earth at the moment
Not sure, but I do use US plug to Schucko adapter that has the ground terminal, something that looks like this. (from Google)
-can i change the plug? Though the power supply is bulky, i'd rather build an adapter cable
If you managed to replace it, please, update us, I'm interested too.
-if i wanted to probe between two points at an arbitrary distance... what are the two wire thingie that you can plug on the tip called? Where can i find them?
My probe also missing those tiny accessories, I used small solid copper wires, spun/coil at the drill bit that has the same diameter as those tiny sharp tips, and then attached the coiled copper wire snugly at both tips (also it can be detached), and then soldered the other wires end at the test points.
A ghetto mod, but it works.
