Author Topic: Tektronix Common Design Parts Volumes 1 to 4  (Read 2616 times)
Offline perdrixTopic starter
« on: August 23, 2018, 10:04:55 am »
I've just uploaded these to ko4bb.com:
http://www.ko4bb.com/getsimple/index.php?id=manuals&dir=07_Recent_Uploads
Thanks to Pete Lancashire for the scans
Dave Partridge
The following users thanked this post: JPortici
Offline LapTop006
Re: Tektronix Common Design Parts Volumes 1 to 4
« Reply #1 on: August 24, 2018, 02:08:06 am »
They don't show download links for me?
Offline iainwhite
  • Measure twice...
« Reply #2 on: August 24, 2018, 02:19:15 am »
There is a comment in the header:
"These files cannot be downloaded yet.
They will be moved to their respective directories after being checked out."
I guess they are awaiting some sort of admin review/approval
« Reply #3 on: August 24, 2018, 08:58:39 am »
Didier has now moved them to:
http://www.ko4bb.com/getsimple/index.php?id=manuals&dir=Tektronix
I've since uploaded two more ...
Cheers
Dave
The following users thanked this post: iainwhite
Offline PartialDischarge
« Reply #4 on: October 22, 2018, 05:52:27 am »
I wish Tektronix finally released the handbook on design and construction on bridged T coils that they must have somewhere  :'(
Offline T3sl4co1l
    • Seven Transistor Labs
« Reply #5 on: October 22, 2018, 02:15:09 pm »
I found a better one somewhere, it covers series, shunt and tapped coil peaking with M-derived prototypes.  If I remember when I get home, I'll find a link for it...
Seven Transistor Labs, LLC
The following users thanked this post: PartialDischarge
Offline duak
« Reply #6 on: October 22, 2018, 07:38:51 pm »
Tim, I recall that Tek had some sort of legal protection for T network IP.  I can't imagine they patented it because that would have brought the IP into the public domain.  Mind you, I didn't try a patent search.   Do you know more about this?
Cheers,
« Reply #7 on: October 23, 2018, 02:39:08 am »
The only patent I know of regarding this is US3155927. Patents back there were so to the point and lacking all the bs of modern ones.
Offline T3sl4co1l
« Reply #8 on: October 24, 2018, 01:51:43 am »
Oh yeah, I remembered! :P
Wideband Amplifiers, Starič and Margan, Springer (2006).
http://www-f9.ijs.si/~margan/WBA3_4web/Wideband_Amplifiers_FPRL.pdf
This link, actually, is probably pretty reliable... that's the author's website, not a copyright violation!
They acknowledge former Tek employees, so this is probably as thorough as anything else. :)
The following users thanked this post: KE5FX, RoGeorge, capt bullshot
Offline capt bullshot
« Reply #9 on: October 24, 2018, 06:46:09 am »
Thanks, really interesting. Now the T-coil is demystified, at least for me. In very terse form: They just turn a single order lowpass filter formed by circuit parasitics into a higher order filter, which has a steeper roll-off and in turn a higher -3dB frequency. Beautiful and simple, though some complex math required for full analysis.
Offline T3sl4co1l
« Reply #10 on: October 24, 2018, 02:08:48 pm »
Yup! :)  It follows that, any system you can increase the order of, while maintaining control of the poles, can be improved in identical fashion.  Take the voltage mode SMPS for example: it has a two pole output filter, plus one more for the controller (assuming a traditional dominant-pole or pole-zero controller).  Downside, the filter pole depends on the attached load, so you can only adjust it to, say, a 3rd order Bessel or Butterworth or whatever, for a given load.
I forget if you can do that with higher order compensators (i.e., more than one integral term), or if the poles stack rather than split, so you have no control over them (integrators at least must, because you only have one degree of freedom per integrator -- its gain -- and the product of any number of integrators still only has one gain term).
It might be doable with a chain of error amps (i.e., one loop is the "plant" of the next loop, and so on), where pole splitting does occur; but it need not be straightforward what the trajectory of all those poles is, and if you can coax them onto a circle or ellipse for anything, as needed for a known filter type.  Or if the result is any less sensitive to source/load conditions.  (In other words: you can try playing with your piezo stack and compensating it in this way, but you're much more likely to be fruitful, using a more conventional method like cancelling the dominant resonance in the loop. :P )
