So, I'm waiting for this 7075 to warm up so I can see exactly how far off reality it is.
So far, it's been an hour and 20 minutes since I turned it on and I'm watching the internal reference voltage. It's been climbing, more and more slowly since I turned it on - as you'd expect.
Up until this time, the rate of change had been slowing from 1uV increase every 4 minutes to 1uV every 10 minutes. The last change was up one more uV after 12 minutes. I'd nearly said "OK, time to connect the voltage reference!".
Then, all of a sudden, the reference voltage dropped an entire 18uV in the space of one 10 second integration!
Now it's circling around a +/- 1.5uV range. If it stays that way, I guess I finally shook the cobwebs out of the internal reference!
Looking at the address of the seller on Google maps leads me to believe that his stock is stored outside in shipping containers. I can see some rust spots on a metal can down in the analogue section, so who knows how long this meter has suffered cold and humidity in some rusty old shipping container?
If it is still holding the same range in another 15 minutes, I'll get a reference and some Vishay 0.005% resistors on it and see if, in Dave's words, I can say: winner, winner, chicken dinner!
