Author Topic: Test Equipment Anonymous (TEA) group therapy thread  (Read 1371035 times)
mnementh, Eric-H, Neonuros, Brumby, scl (+ 1 Hidden) and 7 Guests are viewing this topic.
Online mnementh
« Reply #29975 on: April 23, 2019, 10:36:24 pm »
   The parts donor 53310A I picked up just for the OCXO option was not as dead as the seller made it out to be.  Just needed some caps in the power supply.  Repair successful and wont have to worry about the caps for another 25 years.  All Rubycon ZLH series (nothing but the good stuff).  I ordered enough parts to re-cap my primary 53310A, will have to pull it apart soon, I'm sure it's just a matter of time.
So you encountered the same thing as I did recently with a 465B. Purchase one being sold as "parts only" so it will be a parts mule. Discover it only needs some minor work to get it running. Now have 2.  :-+
Yeah.... ever notice how sometimes a just turns :-DD
   Unable to sleep, so I set to cleaning up the front panel of the 7904A. Overall not bad at all, but definitely some grunge and grime in crevices and a few nasty spots of old adhesive. Also got some grunge out of the knurling on a few knobs, mainly on the 7A26 amplifier. Also cleaned the blue filter and and removed an annoying stuck on bit of grunge from the implosion shield. Now that I've unstuck the variable control on the 7B15 delaying timebase, she's looking and performing great. The only thing left to do is compensate the 7A26, but I'm saving that job for another day based on what I heard from med.  :-+
Tasty!  :-+
*Jealous not only of these delicious boat anchors, but the space to live with them*
That's what I thought but how many people go around stuffing fingers in the inlet, er, you do apparently for one  :-DD
Yes he does, on purpose.  :-DD :-DD
Maybe that explains why he also loves to blow things up  :-DD
That's a chicken/egg dilemma because apparently he was blowing things up before he enjoyed shocking himself.  :P :P :-DD
I'll just refer you both to "The 10 11 Laws of TEA"...
11. Masochism is endemic, perhaps even mandatory.
    :-DD
"A little pleasure.... a little pain... it's a-a-all good." *sigh of delight* ~me
Online mnementh
« Reply #29976 on: April 23, 2019, 10:55:41 pm »
That's what I thought but how many people go around stuffing fingers in the inlet, er, you do apparently for one  :-DD Seriously, these are not going to be unplugged, they will static on my wall of meters sitting on the shelf above the bench, so I'll leave them as they are and transfer the earth leads over, thanks for confirming my suspicions.
When this one bites you it's usually when I run out of sockets and have to move things around. I pull the mains lead out then accidentally touch the prongs. It's a pretty minor ping but unpleasant. Makes you drop the plug!
Hows your elbow this morning, if its anything like my sons knee cap it will be slow to repair itself and painful for a long time so make sure you have plenty of pain killers handy. Personally I find that the Deep Heat cream is quite good if you can put up with the smell of it.
Better actually. Can't fully extend or contract it but the swelling has gone down a bit. I think this one might be a quicker recovery than your son's knee. Naproxin FTW although it's making me feel sick. I'm still going to try and hit the radio rally in Andover on Sunday and have Avengers Endgame booked on Thursday which I will Uber myself to :D
Settling in this evening to catch up on crap films. First we have Velocipastor: https://www.imdb.com/title/tt1843303/
Edit: HP 3310A is apparently arriving in the next 3 hours  :-+
@spec - Of course your question is rhetorical; it clearly wouldn't take but a minute to transfer the entire harness over to the new filter. So then comes the question of motivation... I suspect you more wanted validation of your "meh" proclivities than actual technical advice.  ;)
@med: "Only slightly more predatory than regular priests!!!"   :-DD
Offline tggzzz
« Reply #29977 on: April 23, 2019, 11:52:39 pm »
My attitude is to minimise the use of painkillers during the day, but dose myself at night for a good sleep. The exception to that is if minimising swelling will aid recovery, in which case I'll take paracetamol/ibuprofen.
Don't forget you can take a max dose of ibuprofen plus a max dose of paracetamol, since they have different metabolic pathways. Be aware that the max dose of paracetamol has been reduced from 90 to 65mg/kg of body weight, so 4*2 tablets can be a bit dicey if you are small.
What happens if you exceed that? Well, paracetamol is extremely safe up to a limit; beyond that the bodies' metabolic pathway is saturated and so a different metabolioc pathway kicks in. The latter creates formaldehyde, which is bad news for the liver!
Maybe I've been lucky or insensate, but even after an operation I haven't had to use the tramadol they've sent home with me.
As for Andover, what would happen if you get there and your elbow strongly suggests you shouldn't drive back?
« Reply #29978 on: April 24, 2019, 12:10:50 am »
First one of the 7150 Plus meters is fitted with its new filter and has been test now 75 minutes and it would appear to be in pretty good condition as regard to its DC Volts calibration as this photos shows, it ties nicely with my other meters apart from the HP3468A which is reading a little low and I can calibrate this but haven't bothered as yet as it is certainly near enough for my purposes. So far I call that a win, on to meter number 2 in a little while, off to the hospital with my son now for physio therapy.
The following users thanked this post: med6753, kj7e, bd139, PrecisionAnalytic, grizewald
Online mnementh
« Reply #29979 on: April 24, 2019, 12:47:17 am »
Yup. My usual back pain cocktail is OTC 500mg Acetaminophen/800mg ibuprofen; I try not to do that more than twice in a day. Tramadol was nice for my tooth post-extraction though; I could still think as opposed to the Vicodin which just made me fuzzy. I saved that for when I got woke up in the middle of the night by the pain as it just knocked me right out again. :-+
All gone now... just as well. I have family history of "tendency towards dependency".  :-\
*Back to the salt mines*
« Reply #29980 on: April 24, 2019, 01:10:20 am »
Yes I do the same. I'm actually dropping the naproxin as of this evening's dose and going down to 400mg normal ibuprofen. Once in morning once at night. Paracetamol doesn't work on me at all.
Got some 30/500 co-codamol in the cupboard for emergencies. Couple of them and you could fight a ninja off with your bloody stumps.
As for the Andover, I will see how I feel on the morning. At the moment it's a no but the objective is to keep mobile until that date. Last time I did something like this I was operating normally apart from aches after 4 days. Fortunately it's not that bad so far and getting better rapidly. Been doing light stretching exercises hourly. Also my cousin lives in Andover and I'm going there anyway so I'll crash on the sofa for the night.
Injury shall not defeat the TE addiction though. 3310A arrived and is unpacked and opened for inspection. All this is done with one hand as it's a nice HP chassis that's easy to get into. My eldest got it out of the box. Whole thing is complete and in excellent condition. No sign of any trouble. No bad capacitors. Works perfectly! SN and date codes point to 1984 which is a bit later than I thought. Probably near the end of the line for this little function generator.
Insides
Comes with full original service manual with pull out schematics! Binding was shattered but that can be replaced.
Sitting on the bench. Calibration is pretty good and stability is excellent.
The following users thanked this post: Cubdriver, med6753, kj7e, beanflying, PrecisionAnalytic, grizewald, Kosmic
Offline tggzzz
« Reply #29981 on: April 24, 2019, 01:21:39 am »
Have you been told not to drive? (Daughter was after she broke her elbow two days before a house move, doh.) If so you'll need a medic's OK before you drive again, lest you be uninsured :)
« Reply #29982 on: April 24, 2019, 01:24:05 am »
No they said nothing at all other than fuck off. This is the NHS after all. I won’t drive if it’s not safe to do so. Do not fear. Like I said 80% not likely to go. I’ve set myself a psychological objective more than anything.
« Last Edit: April 24, 2019, 01:25:37 am by bd139 »
« Reply #29983 on: April 24, 2019, 01:31:54 am »
Looking good there. A mighty fine stack of meters too  :-+
Offline tggzzz
« Reply #29984 on: April 24, 2019, 01:37:49 am »
You live in the wrong part of the country, or a face that "stimulates" people :)
Today I had a very pleasant session fitting new deafaids: it took over an hour and three quarters (how much would that cost in the US?), and started with an apology for being 10 minutes late starting. But given that a colleague had come in and then had to go home through illness, I think that was more than acceptable!
My daughter and mother have had similar good experiences.
Offline tggzzz
« Reply #29985 on: April 24, 2019, 01:43:36 am »
Meh. Now try doing it with 7 and 8 digit voltmeters :(
But that deserves an explanation... I'm feeling a bit pissed off ATM, since I can't tell which of these has changed: 7 digit 7075, 8 digit 7081, 5.5 digit  3468, 5.5 digit 1061, two voltage sources.
Fortunately there might be an unofficial calfest nearby next month. I'll wait until after that before tweakign my other 7075 :)
« Reply #29986 on: April 24, 2019, 02:05:35 am »
I think this was down to one particular doctor this experience who appeared to have majored in Thai massage or assassination in a precious life. They’re usually really good here. I was in and xrayed in no time at all. Radiographer and triage nurse were very nice to their patients.
US I’d probably just be deaf or die from thrombosis or something.
« Reply #29987 on: April 24, 2019, 02:47:27 am »
The only way I'll miss this hamfest on Sunday is if I'm dead.  :-DD I heard this is a big one and well attended with lots of vendors. We'll see.
« Reply #29988 on: April 24, 2019, 02:54:18 am »
No. The FIRST question they ask you even if you are bleeding out or have a bullet wound is do you have insurance? They wanna be paid and someone with no insurance is an eventual write off. So they start the "write off" process right from the get go and you may kick the bucket before they get back to you.
« Reply #29989 on: April 24, 2019, 04:31:33 am »
Nah, you mericans have got it all wrong, life is precious and is worth saving, you should all campaign for better from your governments, after all, you can't work to pay your taxes unless you're fit and well. No work, no pay, no spending, no profits, no taxes and that vicious circle could be stopped if your health system was like our NHS, free at the point of delivery.
The following users thanked this post: PrecisionAnalytic
« Reply #29990 on: April 24, 2019, 04:39:10 am »
Offline tggzzz
« Reply #29991 on: April 24, 2019, 04:49:48 am »
I thought you had previously said you were impressed.
Being aloof, superior and not very communicative used to be SOP for medics, back when they couldn't do much and so relied on patients believing what they said. When I was a kid I watch my mother deal with a competent Sir Lancelot Spratt; it was educational to see him realise he had been rumbled :)
Nowadays enterprise server software consultants have probably taken up that Spratt mantle, especially in the fintech sector ;)
« Reply #29992 on: April 24, 2019, 05:00:52 am »
I was impressed overall. Just that was a low point :)
There are plenty of Spratts out there. Dealing with them is my forte. I'm more a Dell Boy selling dodgy spoons.
This is an accurate portrayal of the average NHS experience, from Monty Python. I'm not moaning - a couple of family members have had near misses which would have cost 6/7 figures in the US and walked away alive...
Online mnementh
« Reply #29993 on: April 24, 2019, 05:15:54 am »
It's not that "we the people" haven't campaigned; and it's not that "we the people" haven't voted for such measures every every chance we get. It's that the votes are counted by the same corrupt motherfuckers who've been bought by and who are selling us all by the pound to the corporations that we still treat like God over here.  :palm:
It doesn't matter who votes; it matters who counts the votes.
Online mnementh
« Reply #29994 on: April 24, 2019, 05:19:10 am »
I'd go just to be able to say I took a whizz on Taffy Lane.  :-DD
*dirty-minded ol' reptile* >:D
« Reply #29995 on: April 24, 2019, 05:32:45 am »
Yes yes we know all that and by the way things are going over here, we'll be joining you in that cess pit before much longer as well I fear. I don't think that we have anything else left to privatise. :rant:
Offline bitseeker
« Reply #29996 on: April 24, 2019, 05:42:52 am »
Nice score getting it with an original manual. :-+
Life is better under the TEA. ♪♩♫ Under the TEA. ♩♫
« Reply #29997 on: April 24, 2019, 05:55:35 am »
Arh, yes, the Doctor series of films, I remember them well, for the benefit of others who have no idea what we are talking about here's a short clip.
« Reply #29998 on: April 24, 2019, 06:45:57 am »
I was a Boy Scout for only about a year and never made it past the rank of tenderfoot but I do remember their motto. “Be Prepared”. I am prepared. I always put this in the window at the end of April when it's still cool. There is nothing worse than jackassing these heavy units into the window when it's hot and you got sweaty, sticky and smelly family jewels. So it's installed and tested and ready to go. And it just so happens that it reached 27 C today so the hot weather isn't far off. I am prepared.  :-+
TEA news. The 465B parts mule shipped. According to FedEx it will arrive tomorrow. I doubt that. It's coming from Baltimore. But we'll see. Maybe I'll get a surprise. :-//
Offline grizewald
« Reply #29999 on: April 24, 2019, 06:52:59 am »
First one of the 7150 Plus meters is fitted with its new filter and has been test now 75 minutes and it would appear to be in pretty good condition as regard to its DC Volts calibration as this photos shows, ...
The curse of precision. This trio are nearly in agreement, but it varies from range to range. Of course, my voltage source isn't calibrated either.
Getting even one of them properly calibrated and adjusted would probably cost more than I paid for the entire contents of my messy bench.
What's a man to do?  :-//
