Author Topic: Test Equipment Anonymous (TEA) group therapy thread  (Read 14943614 times)
Carl_Smith, K0ELB and 193 Guests are viewing this topic.
Offline Mr. Scram
  • Display aficionado
« Reply #3075 on: October 23, 2017, 05:27:05 pm »
I was bidding on a decade resistance box today, but got saved by the ridiculous prices. Some of those boxes go for outright stupid prices.
« Reply #3076 on: October 23, 2017, 05:32:11 pm »
Yeah they go for insane amounts. No idea why. They’re just some resistors and switches in a damn box.
I have taken to just soldering a pot in and then pulling it and measuring it or just using fixed values. I was going to make one but for the sake of using it once every week or two it’s not worth the time and cost.
Offline Mr. Scram
« Reply #3077 on: October 23, 2017, 05:34:14 pm »
It seems the ones with single ohm or even tenth ohm scales go for even more money. I'm not that's absolutely necessary, although single ohm would be nice.
I do already own a capacitance box, so having a resistance box should make for some filtering fun. That's pretty much my main concern, plus maybe easily stepping through values to test the multimeters.
« Last Edit: October 23, 2017, 05:36:07 pm by Mr. Scram »
« Reply #3078 on: October 23, 2017, 05:42:25 pm »
I’ve got some 0.1% Dale RN55 resistors for DMM checks. They were a whopping £1 (about $1.25) delivered.
Offline Mr. Scram
« Reply #3079 on: October 23, 2017, 05:49:57 pm »
Sure, there are other options. However, a lot of the additions to the lab are based on increasing comfort and speed, rather than just capabilities, and a decade resistance box fits that idea nicely.
The only regret I'm really having is not investing in proper kit sooner. I want tools that help me get the job done, rather than tools that need to be fought to get anywhere.
« Reply #3080 on: October 23, 2017, 06:04:36 pm »
Yes, I've been looking for a while now but they do seem stupid amounts of money, so I'm guessing that they must be equal to or better than .05% resistors in them?
Offline Mr. Scram
« Reply #3081 on: October 23, 2017, 06:07:44 pm »
A lot are 0.1% or even 1%. Granted, you need a handful, it's small scale production and proper switches aren't cheap, but still. Even the Chinese ones are often close to $100.
« Reply #3082 on: October 23, 2017, 07:06:29 pm »
I picked up this little beauty a while back (off the bay, natch), a bit of a cut above your average decade resistance box.
Those are hermetically sealed foil resistors inside, Vishay HPs, which are the precursor to Vishay VHPs which trip in at the £20-30 level for a single resistor. VHPs are 0.005% tolerance and alter less than 60ppm between -55C and +125C. I won't say the annoying low price I won it for for, but it didn't break 2 figures.
Offline Mr. Scram
« Reply #3083 on: October 23, 2017, 07:16:47 pm »
Nice score! It seems that some listings get a lot of attention, and therefore go for insane prices. Unfortunately, most listings I watch lately seem to be of that type.
Offline tggzzz
« Reply #3084 on: October 23, 2017, 07:23:14 pm »
Yes, how annoying (for us :) ).
The nearest I have is a 121.1ohm Dekapot (DP1311), but it has the advantage that the dials go all the way up to 11. It cost all of £10, at a local hamfest.
« Reply #3085 on: October 23, 2017, 07:44:19 pm »
I just missed out on a three decade Dekapot a few weeks back.
« Reply #3086 on: October 23, 2017, 07:51:01 pm »
Back from my local crap merchant and have scored another Tektronix scope, this time a 465B. This one is sick like the 475 was. Apparently people have seen it and run a mile. However it's not all that bad: the CRT is defocused and to the right and intensity doesn't work. The HT is definitely working though so that's less of a worry. Probably power supply or intensity control shot. Time will tell.  And for less than £30 again.
And thus another thread is born: https://www.eevblog.com/forum/repair/tektronix-465b-repair-97327/
Offline guido
« Reply #3087 on: October 23, 2017, 09:35:27 pm »
The 7A13 is a differential comparator with +-10V internal offset. So you can display a 10V DC signal with  1 mV/div resolution.
Those now too are on my list.  :-DD
Small correction however, you said 7804 while mine is 7704A
Keep in mind that the 7A13 is full of very Tek specific relays. With a footprint that prevents an easy replacement. Unfortunately they do fail on a regular basis, specially the double contact ones. In the old days they actually repaired them, using a Dremel to open them. I made two test jigs to test them. Seems to help if you connect them to a FG and let them switch a large number of times.
Tek 7k stuff is addictive. On the bench: 7603 with 7A22, 7A13 and 7B53A. 7623A with 7L5+TG. On cart: 7704A with 7A18, 7S11, 7T11 and 7B70. Then 5 more 7xxx mainframes as spare and a number of parts/fix-up plugins. Like another 7L5 (looking for the big knob assembly), 7A13 without relays (guess why), some more 7A..amps and a number of spare 7B53As. And one self made 7xxx extender cable. About half the mainframes have new PS caps, using adapter pcb's. I had to fix the 7704A a number of times. Bad resistors/arcing in the HV section. Primary bridge rectifier shortened and a shortened tant cap somewhere. Keeps you busy. But all easy fixes.
I have a similar list of TM5xx(x) stuff, next to the regular gear. Yep, I fit in here  :)
« Reply #3088 on: October 24, 2017, 06:07:27 am »
I am in the middle of assembling my own resistor box (seven decades, starting from 0.1 Ohms). It is not super accuate, something between 0.1 and 1% but it fits for my needs. The switches are relays and the value is directly showed with some nice red Kingsight 7-segements LEDs. The value will be set by 7 BCD rotary switches.
Yeah, I know, it is a kind of overkill and not optimal, but I like the fun in assembling it.
If you (people from the forum here) are interested, I'll show (in a separate thread) the schematics and pictures of it.
« Reply #3089 on: October 24, 2017, 06:15:52 am »
That's what counts!
Of course! Was that a trick question? ;D
« Reply #3090 on: October 24, 2017, 06:18:36 am »
Take a look at what's painted on the top of this Fluke 8800A. Is it a sign? :-DD
https://www.ebay.com/itm/Fluke-8800A-Digital-Multimeter-Power-Tested-/232530603798
(Warning: There's a sizable chunk of the side of the case missing.)
« Reply #3091 on: October 24, 2017, 06:23:36 am »
You'll never know ...  ;D
« Reply #3092 on: October 24, 2017, 06:24:36 am »
As long as you post the link here, all will be well. :-+
« Reply #3093 on: October 24, 2017, 06:26:28 am »
If you have ever seen "Sleepless in Seattle" then you'll know: everything could be a "sign"  ;D
(love the scene when they discussing movie scenes  ^-^ )
« Reply #3094 on: October 24, 2017, 06:55:51 am »
Haha, they even have the cheek to describe it as being in Very good cosmetic condition with no dents or dings, the sign is great though.
Offline Cubdriver
  • Nixie addict
    • Photos of electronic gear
« Reply #3095 on: October 24, 2017, 07:35:32 am »
Well, it doesn't have any dents or dings.  They say nothing about it not having a chunk missing...   :-*  Besides, that opening helps with cooling!   ;)
(Watching for curiosity's sake, have no intention of attempting to buy it)
-Pat
Offline Berni
  • Country: si
« Reply #3096 on: October 24, 2017, 07:54:36 am »
[img]
[img]
Now that is a true beauty of a resistance box! Amazing bargain there!
I did get a set of DC-20GHz attenuators in the original wooden box with the original factory cal sheet(with data) inside in almost perfect condition for like 50 bucks. They are all N connector tho, would have preferred SMA.
« Reply #3097 on: October 24, 2017, 10:21:17 am »
My 6206B is arriving today and I'm suffering from a bad case of late-stage-SAD. I came across this earlier which is a nice board game for those of you anxiously waiting for that wonderful dose of TEA to arrive. Open image in a new tab if you can't read it :)
The following users thanked this post: Specmaster, URI
Offline ChrisLX200
« Reply #3098 on: October 24, 2017, 11:31:02 am »
LOL! some of those are too painfully accurate :-) Had the issue of the driver claiming he attempted delivery when no-one was at home... BS.
« Reply #3099 on: October 24, 2017, 11:34:03 am »
Yeah I caught the bastard doing that the other day. Made him go back to the van and get it.
