Products => Test Equipment => Topic started by: nbritton on November 26, 2015, 04:32:48 pm
Title: The screen colors on my Rigol are inverted.
Post by: nbritton on November 26, 2015, 04:32:48 pm
Take a look at the picture, I turned on my Rigol MSO4014 today and the screen colors appear inverted. Their is also a flicker on the screen. The video on the VGA out port is the correct color.
(http://www.eevblog.com/forum/testgear/the-screen-colors-on-my-rigol-are-inverted/?action=dlattach;attach=183808)
(http://www.eevblog.com/forum/testgear/the-screen-colors-on-my-rigol-are-inverted/?action=dlattach;attach=183810)
Title: Re: The screen colors on my Rigol are inverted.
Post by: tautech on November 26, 2015, 04:36:02 pm
Display options....Invert?
Post by: nbritton on November 26, 2015, 04:56:16 pm
No I don't think there is an invert option in the menus. Even the bootup screen is inverted.
Post by: blueskull on November 26, 2015, 05:06:15 pm
This shows in the middle of hacking it or long after or before hacking it?
If it is the latter, you can un-hack it and request a RMA.
Post by: nbritton on November 26, 2015, 05:18:53 pm
I left it on for like a 30 minutes and now the screen is black again, but it is washed out, the contrast is jacked.
(http://www.eevblog.com/forum/testgear/the-screen-colors-on-my-rigol-are-inverted/?action=dlattach;attach=183815)
Post by: blueskull on November 26, 2015, 05:20:19 pm
Typical LCD failure or biasing circuitry failure. Unless you want to do a big tear down and spent $100-ish to buy a new LCD, return it.
Post by: Whales on November 26, 2015, 05:41:57 pm
It may be as a bad connector to the LCD.  Gently poking around with a pencil on flat flex cables and connectors near/on the screen can identify this.  A problem that looks this consistent suggests it may be a fault in a parallel signalling interface (where one bad connection causes ~1 fault), so the cables with the most traces are the ones you should be looking at.
Post by: nbritton on November 26, 2015, 05:59:23 pm
I left it off for like 30 minutes and then turn it back on and now its normal. Now it's broken again... it appears to break only when I want to use it, it's like a mysterious Rigol quantum observer effect  :-//  :-BROKE
Post by: crispy_tofu on November 26, 2015, 06:02:40 pm
That happened on one of my Acer laptops a few years ago... something in the display might be dying.  :scared:
Could just be a loose cable or something, though...
Post by: nbritton on November 26, 2015, 06:56:50 pm
I would void the warranty if I opened it up for the purposes of repairing it. In the USA, only modification is allowed (due to the Magnuson–Moss Warranty Act) without voiding the warranty per the fine print in the Rigol warranty contract. See section 5(4) (http://www.rigolna.com/warranty/):
5. The warranty is void if:
(1) Accidental damage occurs during transportation (please confer with insurance agency or transportation company on the compensation).
(2) Malfunction or damage is caused by misuse according to warnings in the product documentation or using or storing in an environment outside of the specification’s limits.
(3) Surface damage by manmade factors, like burn, distortion by force, etc.
(4) Repaired by anyone who is not from RIGOL Maintenance Center or an authorized maintenance branch.
(5) Accident damage caused by using a power cord or a power adapter not approved by RIGOL.
Post by: blueskull on November 26, 2015, 07:20:50 pm
Just throw it back to Rigol and let them do the job. That's why they gave you 90 days warranty.
Post by: dadler on November 27, 2015, 07:54:32 am
You'll need to send it back to Rigol for repair.
Here is how my repair went: http://www.eevblog.com/forum/testgear/rigol-ds2072a-spurious-signals-and-display-corruption/ (http://www.eevblog.com/forum/testgear/rigol-ds2072a-spurious-signals-and-display-corruption/)
Post by: Zero999 on November 27, 2015, 10:27:11 am
I don't know what it's like where you live but here in the UK, if a product is faulty, you should return it to the retailer/distributor, as that is who you made the contract with, rather than the manufacturer.
