One of my long standing wishes was to get a digital pattern generator for my Tektronix TLA715 logic analyser. I almost gave up and started looking for alternatives but then an EEVblog member from Poland put one up for sale including a logic POD and the cable in one complete set.
The TLA7PG2 can have up to 64 channels, 2Mpts of memory and rates up to 250MHz (the latter with half the channels enabled so the datarate and memory double). When I got the module it had the standard length of 64kpts (option STD). The TLA7PG2 module is made by Sony/Tektronix like several other older signal generator products from Tektronix.
This is how the TLA2PG2 module looks like (picture from internet):
And this is the logic POD (picture from internet):
The inside of the P6470 POD:
I didn't expect this many heatsinks and a fan inside the P6470 POD. It has adjustable output levels from 2V to 5V but that shouldn't be so hard to accomplish.
Now for the uphack to get my module from STD (32kpts on 64 channels) to 1M (1Mpts on 64 channels). This works similar to hacking the acquisition modules. However instead of the depth the option is set directly.
The *IDN? command returns:
SONY/TEK,TLA7PG2,J0320135,SCPI:93.0 FW:2.01 HW:1.00, build: May 18 2001 14:00:19
The part after the firmware version is used to send the password, then the option setting and then the update command to finalise the setting:
SYST:PASS:INST:PASS "FUJIHIKO2.01"
SYST:CONF:OPT OPT1M
syst:pass:inst:upd 1522422274
The number 1522422274 is the current UTC timestamp (google that to get the current number)
