Author Topic: TY720, KEW 1062, handheld multimeter, Inside High resolution images  (Read 10563 times)
Offline fanOfeeDIYTopic starter
  • Country: jp
    • YouTube Channel
I finally took all the images inside Kyoritsu KEW1062, which is same as Yokogawa TY720.
I also uploaded a video of tear down.
https://youtu.be/7u3v8R-L7-I
Front side.
« Last Edit: May 04, 2018, 06:20:15 am by fanOfeeDIY »
The following users thanked this post: BravoV, Bud, arturmariojr
  • Country: jp
    • YouTube Channel
Re: TY720, KEW 1062, handheld multimeter, Inside High resolution images
« Reply #1 on: April 24, 2018, 06:20:14 am »
next
The following users thanked this post: arturmariojr
  • Country: jp
    • YouTube Channel
« Reply #2 on: April 24, 2018, 06:20:47 am »
next
  • Country: jp
    • YouTube Channel
« Reply #3 on: April 24, 2018, 06:21:34 am »
next
  • Country: jp
    • YouTube Channel
« Reply #4 on: April 24, 2018, 06:25:23 am »
next
  • Country: jp
    • YouTube Channel
« Reply #5 on: April 24, 2018, 06:28:38 am »
next
  • Country: jp
    • YouTube Channel
« Reply #6 on: April 24, 2018, 06:31:54 am »
a
  • Country: jp
    • YouTube Channel
« Reply #7 on: April 24, 2018, 06:34:13 am »
Back side
« Last Edit: April 24, 2018, 06:49:21 am by fanOfeeDIY »
  • Country: jp
    • YouTube Channel
« Reply #8 on: April 24, 2018, 06:35:19 am »
next
  • Country: jp
    • YouTube Channel
« Reply #9 on: April 24, 2018, 06:38:51 am »
a
  • Country: jp
    • YouTube Channel
« Reply #10 on: April 24, 2018, 06:42:40 am »
a
  • Country: jp
    • YouTube Channel
« Reply #11 on: April 24, 2018, 06:43:25 am »
MCU
  • Country: jp
    • YouTube Channel
« Reply #12 on: April 24, 2018, 06:44:42 am »
a
  • Country: jp
    • YouTube Channel
« Reply #13 on: April 24, 2018, 06:47:15 am »
Analog device
2.5 V/3.0 V
High Precision Reference
  • Country: jp
    • YouTube Channel
« Reply #14 on: April 24, 2018, 06:50:21 am »
I think I finished uploading the images.
Offline HKJ
    • Tests
« Reply #15 on: April 24, 2018, 06:59:30 am »
Interesting, no multimeter chipset but implemented with a 24 bit ADC (ADS1240) and a processor.
Online Fungus
Offline BravoV
  • +++ ATH1
« Reply #17 on: April 24, 2018, 07:26:28 am »
Arigatōgozaimasu fanOfeeDIY san.
PS : Regarding photos attachment in a single post, you can put up to 25 attachments (max. 2MB total), all you need is just click the tiny words -> (more attachments) when you're attaching photo, its right below the "Browse" button when you're going to select the file you want to upload. Yes, its easy to miss it.
« Last Edit: April 24, 2018, 07:31:09 am by BravoV »
Offline BravoV
  • +++ ATH1
« Reply #18 on: April 24, 2018, 07:34:47 am »
Damn, that's a LOT of ICs.  :o
I guess this meter is easy to fix as no proprietary chip used ?
Offline BravoV
  • +++ ATH1
« Reply #19 on: April 24, 2018, 07:37:26 am »
Are those two clear glass neon bulbs like at the right are GDT ?
Online Fungus
« Reply #20 on: April 24, 2018, 08:01:41 am »
I'm guessing so, although they're a bit how-you-doing.
Some of that hand-soldering is really nasty and those input jacks and current shunt need a bit more solder IMHO.
« Last Edit: April 24, 2018, 08:58:08 am by Fungus »
Online Fungus
« Reply #21 on: April 24, 2018, 08:06:51 am »
Just looking at them: There's a whole bunch of 8-bit shift registers. Are they implementing the LCD driver in discrete logic?  WTF? :o
Edit: No, they aren't. All the tracks to the LCD connector come from the main chip. What are all the shift registers for, then?
« Last Edit: April 24, 2018, 08:16:00 am by Fungus »
Offline HKJ
    • Tests
« Reply #22 on: April 24, 2018, 08:11:12 am »
They must need a lot of I/O's, not only for the LCD (A shift register only works for simple LCD's), but also for the DMM part, there must be lots of MUX's to control for auto ranging and modes.
  • Country: jp
    • YouTube Channel
« Reply #23 on: April 24, 2018, 08:30:32 am »
Oh, I thought that chip was DMM chipset.
I should have took the close up image of it.
I have been open up the meter about tree time already from last evening. :)
  • Country: jp
    • YouTube Channel
« Reply #24 on: April 24, 2018, 08:48:06 am »
Ahh, that was the reason for the error message. :)
I tried to make the images to be high resolution and end up making each jpg file slightly less than 1MB,
and end up attaching more than three images being caught with warning of the 2MB. :)
So I just started to attach one image at the time.
And then the next warning was that I need to wait 30 sec each for next posts.
Probably I will compress more and reduce the file size, next time.
Thinking to do the same for Hioki DT4282.
« Last Edit: April 24, 2018, 10:50:38 am by fanOfeeDIY »
Online Fungus
« Reply #25 on: April 24, 2018, 08:59:06 am »
Go for it!
Online joeqsmith
« Reply #26 on: April 24, 2018, 10:55:30 am »
First, thanks again for taking the time to post these.   My first impression was, wow they have a nice shield on both sides of the meter.  Gossen could learn from them.   Then I thought the meter reminds me of that Keysight meter I ran with all the ICs on it.
It looks like they have the basic resistor, PTC then to the GDT with the two GDTs common in the center.   I can't tell if that center axial part ties to the common point which wouldn't make much sense.  I can't see the return path.  If the board is still out of the case, maybe hold it in front of a light so we can see the inner layers more easily.
I have not found anything on the tubes they use but I'm guessing the 202 would be a 2KV part.   It's difficult to say how it would hold up.
There appears to be some plastic from the case on the board.
Online joeqsmith
« Reply #27 on: April 24, 2018, 11:07:58 am »
Just finished watching the video.  Did you by chance take any pictures of the wiper contacts?
At 6:40,  I thought with the two traces routing to the jacks, they were maybe detecting the leads being wrongly inserted which would need the split connectors.   Maybe a design prior to adding the shutter.
Online coromonadalix
« Reply #28 on: April 24, 2018, 08:42:43 pm »
I cant understand why they did not use an dedicated dmm front end chip ???  tons of chipe here, the battery life must be ordinary ??
and the board is not cleaned after soldering  outch   :palm:
  • Country: jp
    • YouTube Channel
« Reply #29 on: April 30, 2018, 12:20:41 pm »
Took pictures.
Uploading the wiper contacts.
  • Country: jp
    • YouTube Channel
« Reply #30 on: April 30, 2018, 12:23:46 pm »
I tried one with the light from the back.
  • Country: jp
    • YouTube Channel
« Reply #31 on: April 30, 2018, 12:34:04 pm »
My first impression when I open the case was the same as others.
The flux residues are left on the PCB.
My knowledge is that the best insulating material is the air,
and I worried that the flux would led arching when the transient voltage/current comes in.
The DMM itself looks at least six years old by observing the case and contacts,
the color of flux is still clear and have not changes to yellow which is normally one of the cause of corrosion.
  • Country: jp
    • YouTube Channel
« Reply #32 on: April 30, 2018, 01:42:29 pm »
Thanks! :)
I removed it. It was the rubber from the surface of outer of the back case.
There are some peeling on the rubber surface of the corner of the case by probably the drops in the past,
and I must have put them inside when I open the case.
I looked around the case and there were no way that the peeling could go inside the case other than myself. :)
It could have changed the transient test too.
Offline joseph nicholas
  • Country: mx
« Reply #33 on: April 30, 2018, 02:28:06 pm »
It kind of looks like the company is reinventing the wheel with this meter, look at how they are doing measurements an calculations.  It sure is novel.
  • Country: jp
    • YouTube Channel
« Reply #34 on: May 01, 2018, 10:43:03 am »
One of the reason I could think of why they have not used any of the DMM chipset could be that
one of the selling point of the TY720/KEW1062 is that it is able to calibrate by any user who
has references.
It show the User Calibration Function from page 107 to 111.
https://cdn.tmi.yokogawa.com/IMTY720-E.pdf#%5B%7B%22num%22%3A112%2C%22gen%22%3A0%7D%2C%7B%22name%22%3A%22Fit%22%7D%5D
« Reply #35 on: May 03, 2018, 02:54:59 am »
oh ho   nice of them to show us how to calibrate it ...  picked points here :)
Offline emartine
  • Country: ar
« Reply #36 on: March 08, 2019, 07:32:34 pm »
KYORITSU 1062 and YOKOGAWA TY720 are just the same?
Arent they both different companies?
Are they really MADE in Japan? Or built in China?
Thanks.
Online Fungus
« Reply #37 on: March 08, 2019, 08:26:56 pm »
Rebranding of meters by different companies happens all the time in the multimeter world.
Offline sambonator
« Reply #38 on: March 08, 2019, 08:34:12 pm »
TEquipment lists this multimeter's Country of Origin to be Thailand.
Offline helius
« Reply #39 on: March 08, 2019, 10:56:22 pm »
The Yokogawa meters are marked "Made in Japan". They are the OEM for Iwatsu (VOAC22) and Kyoritsu (KEW 1062), although those rebadged meters do not seem to have the simultaneous AC/DC display mode marked. Mine has the solder residues as well.
« Last Edit: March 08, 2019, 11:00:41 pm by helius »
  • Country: jp
    • YouTube Channel
« Reply #40 on: March 09, 2019, 01:48:39 am »
joe smith have uploaded excellent review video on TY720.
The first one is one and half hours long. It gave me enjoyment of three days last week to finish watching it.
Online joeqsmith
« Reply #41 on: March 09, 2019, 02:15:11 am »
That is dedication.   Glad you enjoyed them.    Now, after seeing the Yokogawa punished, are you going to send me your high end Hioki?   :-DD :-DD
The following users thanked this post: fanOfeeDIY
  • Country: jp
    • YouTube Channel
« Reply #42 on: March 09, 2019, 03:32:03 pm »
The damage from your thorough robustness test would be a story it would be passed for generations in my families :)
Offline windsmurf
« Reply #43 on: March 10, 2019, 10:18:33 pm »
So when can we expect Joe to forge for you your family heirloom?
