Author Topic: TY720, KEW 1062, handheld multimeter, Inside High resolution images  (Read 10549 times)
Offline Fungus
Re: TY720, KEW 1062, handheld multimeter, Inside High resolution images
« Reply #25 on: April 24, 2018, 08:59:06 am »
Thinking to do the same for Hioki DT4282.
Go for it!
Offline joeqsmith
« Reply #26 on: April 24, 2018, 10:55:30 am »
First, thanks again for taking the time to post these.   My first impression was, wow they have a nice shield on both sides of the meter.  Gossen could learn from them.   Then I thought the meter reminds me of that Keysight meter I ran with all the ICs on it.
It looks like they have the basic resistor, PTC then to the GDT with the two GDTs common in the center.   I can't tell if that center axial part ties to the common point which wouldn't make much sense.  I can't see the return path.  If the board is still out of the case, maybe hold it in front of a light so we can see the inner layers more easily.
I have not found anything on the tubes they use but I'm guessing the 202 would be a 2KV part.   It's difficult to say how it would hold up.
There appears to be some plastic from the case on the board.
Offline joeqsmith
« Reply #27 on: April 24, 2018, 11:07:58 am »
Just finished watching the video.  Did you by chance take any pictures of the wiper contacts?
At 6:40,  I thought with the two traces routing to the jacks, they were maybe detecting the leads being wrongly inserted which would need the split connectors.   Maybe a design prior to adding the shutter.
Offline coromonadalix
« Reply #28 on: April 24, 2018, 08:42:43 pm »
I cant understand why they did not use an dedicated dmm front end chip ???  tons of chipe here, the battery life must be ordinary ??
and the board is not cleaned after soldering  outch   :palm:
Offline fanOfeeDIYTopic starter
  • Country: jp
    • YouTube Channel
« Reply #29 on: April 30, 2018, 12:20:41 pm »
Took pictures.
Uploading the wiper contacts.
  • Country: jp
    • YouTube Channel
« Reply #30 on: April 30, 2018, 12:23:46 pm »
I tried one with the light from the back.
  • Country: jp
    • YouTube Channel
« Reply #31 on: April 30, 2018, 12:34:04 pm »
My first impression when I open the case was the same as others.
The flux residues are left on the PCB.
My knowledge is that the best insulating material is the air,
and I worried that the flux would led arching when the transient voltage/current comes in.
The DMM itself looks at least six years old by observing the case and contacts,
the color of flux is still clear and have not changes to yellow which is normally one of the cause of corrosion.
  • Country: jp
    • YouTube Channel
« Reply #32 on: April 30, 2018, 01:42:29 pm »
Thanks! :)
I removed it. It was the rubber from the surface of outer of the back case.
There are some peeling on the rubber surface of the corner of the case by probably the drops in the past,
and I must have put them inside when I open the case.
I looked around the case and there were no way that the peeling could go inside the case other than myself. :)
It could have changed the transient test too.
Offline joseph nicholas
  • Country: mx
« Reply #33 on: April 30, 2018, 02:28:06 pm »
It kind of looks like the company is reinventing the wheel with this meter, look at how they are doing measurements an calculations.  It sure is novel.
  • Country: jp
    • YouTube Channel
« Reply #34 on: May 01, 2018, 10:43:03 am »
One of the reason I could think of why they have not used any of the DMM chipset could be that
one of the selling point of the TY720/KEW1062 is that it is able to calibrate by any user who
has references.
It show the User Calibration Function from page 107 to 111.
https://cdn.tmi.yokogawa.com/IMTY720-E.pdf#%5B%7B%22num%22%3A112%2C%22gen%22%3A0%7D%2C%7B%22name%22%3A%22Fit%22%7D%5D
« Reply #35 on: May 03, 2018, 02:54:59 am »
oh ho   nice of them to show us how to calibrate it ...  picked points here :)
Offline emartine
  • Country: ar
« Reply #36 on: March 08, 2019, 07:32:34 pm »
KYORITSU 1062 and YOKOGAWA TY720 are just the same?
Arent they both different companies?
Are they really MADE in Japan? Or built in China?
Thanks.
Offline Fungus
« Reply #37 on: March 08, 2019, 08:26:56 pm »
Rebranding of meters by different companies happens all the time in the multimeter world.
Offline sambonator
« Reply #38 on: March 08, 2019, 08:34:12 pm »
TEquipment lists this multimeter's Country of Origin to be Thailand.
Offline helius
« Reply #39 on: March 08, 2019, 10:56:22 pm »
The Yokogawa meters are marked "Made in Japan". They are the OEM for Iwatsu (VOAC22) and Kyoritsu (KEW 1062), although those rebadged meters do not seem to have the simultaneous AC/DC display mode marked. Mine has the solder residues as well.
« Last Edit: March 08, 2019, 11:00:41 pm by helius »
  • Country: jp
    • YouTube Channel
« Reply #40 on: March 09, 2019, 01:48:39 am »
joe smith have uploaded excellent review video on TY720.
The first one is one and half hours long. It gave me enjoyment of three days last week to finish watching it.
Offline joeqsmith
« Reply #41 on: March 09, 2019, 02:15:11 am »
That is dedication.   Glad you enjoyed them.    Now, after seeing the Yokogawa punished, are you going to send me your high end Hioki?   :-DD :-DD
The following users thanked this post: fanOfeeDIY
  • Country: jp
    • YouTube Channel
« Reply #42 on: March 09, 2019, 03:32:03 pm »
The damage from your thorough robustness test would be a story it would be passed for generations in my families :)
The following users thanked this post: arturmariojr
Offline windsmurf
« Reply #43 on: March 10, 2019, 10:18:33 pm »
So when can we expect Joe to forge for you your family heirloom?
