Author Topic: upgrade New Rigol DS1054Z oscilloscope to firmware 00.04.03.SP2?  (Read 30856 times)
Offline warnbergTopic starter
« on: December 21, 2015, 09:15:56 pm »
Got the new scope, it's running firmware version 00.04.03.SP1... any major fixes or changes or issues with going to the latest firmware version of 00.04.03.SP2 or 00.04.03.02.03 (full version).. can not seem to locate a "fix list" with the new version.. do they not post that, i.e. "this firmware addresses.. blah blah blah"
Just curious what others have done.
thanks
Online Shock
Re: upgrade New Rigol DS1054Z oscilloscope to firmware 00.04.03.SP2?
« Reply #1 on: December 21, 2015, 10:23:18 pm »
Use this thread here for all things DS1054Z:
https://www.eevblog.com/forum/testgear/new-rigol-ds1054z-oscilloscope/
Firmware and release notes:
http://beyondmeasure.rigoltech.com/acton/fs/blocks/showLandingPage/a/1579/p/p-0019/t/page/fm/0
In my opinion unless you are experiencing issues you should wait until the next firmware version is released.
Offline alsetalokin4017
« Reply #2 on: December 22, 2015, 05:31:00 am »
The SP2 firmware did fix a couple of issues that I personally found annoying, but introduced a couple more annoying issues. For my purposes the first point outweighs the second point. But YMMV of course.
Since it is apparently impossible to "roll back" to an earlier version of the firmware, I would advise researching the issues carefully before deciding whether to upgrade to SP2 or not. Myself... I just hope they issue a new firmware update _soon_, that fixes the new annoying issues associated with the SP2 update (the "Pluses" spelling error and the Measurements Fail with Math On bug.)
I've never been able to decode the Chinglish in the changelogs into any language that I can understand. And it seems from my experience that some fixes aren't listed in the changelogs and some things that are listed don't apply to my scope. But that could be down to my lack of understanding of the language used in the changelog.
Offline Hibou
« Reply #3 on: January 01, 2016, 12:52:36 pm »
I recently updated to firmware 00.04.03.02.03 and now the USBTMC command :WAV:DATA? is no longer working in RAW BYTE mode. It was working fine before with firmware 00.04.03.01.05 (= 00.04.03.SP1).
Offline Karel
« Reply #4 on: January 01, 2016, 04:13:50 pm »
I guess there's a problem with your software. Here it works fine with the latest firmware and DSRemote.
No problem or whatsoever whith the command :WAV:DATA? in RAW BYTE mode.
Offline Hibou
« Reply #5 on: January 10, 2016, 02:02:25 pm »
I had the problem when using python-usbtmc version 0.6 under OS X. I have since tried the same Python library under Ubuntu Linux and it works fine. This appears to confirm what Karel said, that the firmware update was not the problem.
Offline Karel
« Reply #6 on: January 10, 2016, 07:17:39 pm »
Don't take my word for it. Grab DSRemote and see for yourself. It's free after all.
Offline ham4me
« Reply #7 on: January 26, 2016, 04:21:45 pm »
My first post to this group so if I'm in the wrong place please point me gently in the right direction.
I'm a new owner of a DS1054Z which was delivered with version 00.04.03.SP2.
Has anyone verified that license codes generated at http://gotroot.ca/rigol/riglol/ are valid for this firmware version.  My attempts to use codes generated there with UltraSigma command :SYSTem:OPTion:INSTall <license>  have not been successful.
Thanks for any assistance
Andy
Offline Karel
« Reply #8 on: January 26, 2016, 04:40:48 pm »
Connect the scope via LAN. Remove the USB cable (if any).
Use telnet or putty.
Check with the command *IDN?. Scope should respond with model and serial number.
Then enter :SYST:OPT:INST <key>
Have fun.
Offline ham4me
« Reply #9 on: January 26, 2016, 05:10:44 pm »
Thanks for the quick reply.
I had no problem connecting with UltraSigma and *IDN? returns the model, serial, and firmware version correctly.
I have just been able to successfully enter the code by direct entry on the scope  so the codes are good for this firmware version!
I assume I must be making a mistake in the command syntax for UltraSigma.  The programming guide says:
Example
:SYSTem:OPTion:INSTall PDUY9N9QTS9PQSWPLAETRD3UJHYA
But
:SYSTem:OPTion:INSTall RDJ9JBBN3SWWUSGJ9A8UJQ8ZXBFA
results in
-> :SYSTem:OPTion:INSTall RDJ9JBBN3SWWUSGJ9A8UJQ8ZXBFA
<- (Return Count:0)
 * Error£¡£¡£¡
VISA:  (Hex 0xBFFF0015) Timeout expired before operation completed.
The same code works when directly entered on the scope.
I'm very happy that the codes work and am not too concerned that I couldn't enable with UltraSigma.
Thanks for a great forum and also to all those that share their "discoveries".
Andy
Offline Karel
« Reply #10 on: January 26, 2016, 06:50:49 pm »
But
results in
<- (Return Count:0)
 * Error£¡£¡£¡
Try:
:SYST:OPT:INST RDJ9JBBN3SWWUSGJ9A8UJQ8ZXBFA
Offline ham4me
« Reply #11 on: January 26, 2016, 09:31:39 pm »
Same result:
-> :SYST:OPT:INST RDJ9JBBN3SWWUSGJ9A8UJQ8ZXBFA
<- (Return Count:0)
 * Error£¡£¡£¡
That's not surprising since the command line parser should accept either the full, or the partial, commands.
I may still be missing something but I'm not going to fret about it.  Too many new features to learn.
Andy
« Reply #12 on: January 26, 2016, 10:46:37 pm »
The UltraSigma software is garbage. I'm surprised you got any response out of it at all.
Offline Karel
« Reply #13 on: January 27, 2016, 07:29:54 am »
There are a lot of things that Rigol's oscilloscope firmware should... but doesn't.
« Reply #14 on: January 27, 2016, 08:50:35 am »
Heh.... and the inverse is true also. There are several things the firmware does do... but shouldn't.
Offline Karel
« Reply #15 on: January 27, 2016, 12:12:24 pm »
Yep...  :(
KiDD
  • Guest
« Reply #16 on: April 05, 2016, 04:54:08 am »
If the upgrade serial has been applied are you able to upgrade firmware like normal?
Offline Karel
« Reply #17 on: April 05, 2016, 06:33:54 am »
In my experience, yes. And I'm not aware of any posters who reported the opposite.
Offline alvesjc
  • Country: pt
« Reply #18 on: July 01, 2016, 05:44:25 pm »
Hello.
I've just received mine.
About the unlocking options, the new firmware accepts the DSFR option? Or we still have problems with the 500uV?
Thank you.
Offline Fungus
« Reply #19 on: July 01, 2016, 06:03:33 pm »
a) Wait a day or two, make sure it works first.
b) 500uV doesn't work. It's a hardware limitation, don't do it.
Offline alvesjc
  • Country: pt
« Reply #20 on: July 01, 2016, 07:35:27 pm »
Ok, thank you for the tips.
Regards
Sent from my ALE-L21 using Tapatalk
Offline ultranalog
  • Audio Nerd - not an audiophool
    • It's only audio
« Reply #21 on: August 01, 2016, 03:10:53 pm »
I just found firmware 04.04 here. Works on my "1104" and my options are still active.
Release notes:
[Updated Contents]
v00.04.04.00.07  2016/07/19
     - Added the full-screen display in the XY mode
     - Modified the Trace data of average sample mode
     - Fixed the bug of system halted for wave persistance in the Zoom mode
     - Fixed bugs about Measure
playing around with near DC (20 kHz) for fun and profit
Offline OE2WHP
  • Country: at
« Reply #22 on: August 02, 2016, 12:43:12 pm »
Release notes are not up to date. :-/
Offline OE2WHP
  • Country: at
« Reply #23 on: August 02, 2016, 03:07:37 pm »
I was eagerly waiting for the Full Screen X-Y feature.
I dared to update and managed not to brick my scope :-)
Now there is an additional button where you can switch between SPLIT and FULL.
All options are still there (including 100MHz).
Here are some screenshots of a 10.7MHz filter with the new full screen option.
Have you noticed that the button is labelled SPLIT when in split mode and FULL when in full mode? Shouldn't it be the other way round, so that the label tells you what will happen if you push the button?
However I'm happy anyhow.
73 de OE2WHP
« Last Edit: August 02, 2016, 03:15:48 pm by OE2WHP »
The following users thanked this post: Fungus
Offline ultranalog
    • It's only audio
« Reply #24 on: April 30, 2017, 11:27:11 pm »
There's a v00.04.04.03.02 out, dated 2017/02/06, http://int.rigol.com/File/ProductSoftWare/20170419/DS1000Z(ARM)update.rar
[Updated Contents]
v00.04.04.03.02  2017/02/06
     - Improved the LXI module
     - Fixed the freeze problem when upgrading based on the boot version of
       0.0.0.13
     - Improved the menu in the language of Traditional Chinese and Korean
     - Modified the failure when downloading waveform to the source module
     - Fixed bugs about reading the memory data through SCPI commands
     - Fixed bugs about Filter
[History]
v00.04.04.01.01  2016/09/14
     - Supported the multi-inteface of LXI
Works for me :)
