TopLoser's multimeter ...[U1252B]...has been sold before I could do enough research to see whether it would fit my needs. I must say the 200000 count Brymen BM869s sounds attractive, even though it lacks mobile logging capabilities. However, I do think I have other priorities at the moment. When I really start needing it, I will evaluate the options to find the most suitable match.
Its predecessor, the
U1252A, is currently available from another member on eBay (nmori87) in NEW condition for $180 + shipping, and he does sell internationally. Dave's also done a review on the U1253A, so you might want to give it a look and see if it's suitable to you (U1252A does do stand-alone logging).
Regarding the Brymen BM869S, it's only a 50,000 count meter (4-4/5 digit). The 500,000 count mode effects resolution in DC mode only (5-4/5 digit). So be aware that DC accuracy remains the same, nor does it work with any other mode.
I suspect pricing will be very similar between the two units. And if this is the case, you'll have to seriously reconsider the desire for stand-alone logging. Especially if its primary use is for bench work, as you'll want access to a PC on the bench anyway.
Louis has posted his video on the Quick. It's what I would consider a rave review.
Thanks.
I'm aware it's up, but haven't watched it just yet.
Edit: I've watched it in its entirety, and Louis's assessment matches my experiences as well (i.e. I've a Luxo swing-arm lamp with a 5000K LED bulb installed, which flickers like a SOB when running the Quick 861DW
). Overall, it's an excellent station, price not withstanding; take the price into consideration however, the value increases significantly IMHO.
Initially, I presumed my experience regarding the lighting flicker was an anomaly. Fortunately, I suspect it can be fixed (shouldn't have to, but the price difference makes the aggravation/fix acceptable IMHO).
FWIW, I've some 5000K LED strips for the underside of my bench; 0.5m on the under-side of each of the lowest half-shelves (2 * 0.5m strips) for bench lighting. They're independently wired with a linear PSU as the primary source of power.
FWIW, I got the PSU (+/- 12V @ 1.7A) as surplus from
Skycraft the last time I was in Orlando in 2014 (paid $15 for the PSU and ~$6 for 4 fl. oz. of Kester 1544).
The caps in mine are of 1996 vintage, nor do they have any leaks or bulges from what I can tell. And they seem OK from what I'm able to test.
