You are topic starter, if yourself is speaking about capacitor tester, then I think that I can also post about testing capacitors:
It is already obvious that the capacitors tested by PA4TIM and yourself have extremely different and even erratic behaviors and that it is therefore impossible to create a model that can predict the leakage current from a low-voltage measurement.
Whatever the reasons for this abnormal behavior, it simply proves that a low-voltage test does not make it possible to verify whether a capacitor is good or not.
Mr. Carlson's claims that the leakage current behaves like a resistance , that's not what you found .... As Dave would do, it's time to push the "fail" button.
My point of view is not that of a theorist, nor of a researcher, but that of a practitioner who seeks practical results.
I work in electronics repair (currently vintage audio with vacuum tubes and transistors) and:
1) It is already extremely rare that I have to test a capacitor with regard to the leakage current because a simple measurement of the voltages of the circuit or of its functionality makes it generally possible to detect this kind of problem (only test needed: measure of capacity)
2) If I have to measure the leakage current, I have to do it at the rated voltage to be sure that the capacitor is working properly when it is powered on.
If the test does not guarantee it, this test is useless and is a waste of time.
Cheaper and simpler to replace the capacitor.
What is a capacitor good or bad? What are the criteria used to determine it?
There are two possible points of view:
1) to measure all the characteristics of the capacitor (measure and not predict!) And compare them with the technical data of the manufacturer.
At the level of repair, it is inapplicable because it takes too much time.
2) to be satisfied with a less rigorous test that detects the breakdown voltage ....
If the breakdown voltage is lower than the nominal voltage, the capacitor is either defective or must be reformed (electrolytic)
It should be noted that the circuits are not all equally sensitive to the leakage current.
For example, in a leakage biased tube circuit with a 10M G1 resistor, the least leakage current of the capacitor coupling it to the preceding stage will prevent the circuit from operating.
On the other hand, if it is a cathode resistance biased stage, where the resistance of g1 is generally of the order of 100K, a low leakage current is acceptable.
There are hundreds of different types of capacitors and dielectrics.
Each has a different behaviour and need his own model.
It's obviously impossible to use hundred of models to predict leakage current from a low voltage test....
The leakage current must be measured at rated voltage, this the only solution.
