Author Topic: Velleman HPS140i miniature DSO - a thing of beauty or ugly duckling ?  (Read 74760 times)
Offline saturation
  • Doveryai, no proveryai
    • NIST
Re: Velleman HPS140i miniature DSO - a thing of beauty or ugly duckling ?
« Reply #100 on: October 21, 2013, 11:42:55 am »
Its OK to bump threads since electronics doesn't change, always good to get updates.  I have the HPS40 which  is the older model.
See p.1 of this thread for a manual.
The trigger indicator is a small "S" beside the waveform.
I've not had trouble with autoranging on the HPS40.
Yes, you cannot save startup settings except when configured from the setup menu.
« Last Edit: October 21, 2013, 02:00:52 pm by saturation »
Best Wishes,
 Saturation
Offline grepas
« Reply #101 on: October 21, 2013, 12:28:19 pm »
On the HPS140, that one just seems to indicate the trigger level, not whether the thing has been trigged or not.
Offline hiddensoul
  • I hack with the battery in..
    • The ham Shack
« Reply #102 on: December 26, 2013, 01:07:17 am »
I was doing some work with a friend who designs controllers. We were fitting a custom micro controller to a sawmill to replace all the old 4000 logic. All of the inputs and outputs from the new controller were done via optos for inputs and relays interfacing to the contactors for complete isolation from the old hardware. The lockout contactor was wired to an opto to prevent the carriage from moving sideways in to the band saw during a cut but the micro kept going from a lock to a safe state even when the contactor was pulled in by input from the operator. We chucked the Velleman across the opto and behold the power rail (12VDC) supplying the old hardware was only half wave rectified. The contactor was holding closed okay but it was freaking out the micro board input. A cap across the opto input and a bleed resistor fixed it. The scope found the problem in 30 seconds and paid for itself in labour savings right there, so was the perfect tool for the job...
Mark "Pockets" Clohesy
http://hamshack.org
VK3PKT
Online FraserTopic starter
« Reply #103 on: December 26, 2013, 12:41:59 pm »
Nice report.
I have found the little 140i to be great for quick checks for situations just as you describe.
She's a compact and useful little tool, if not a sophisticated DSO. I ended up with four of the units, all but one were bought on the secondary market very cheaply. None had received the firmware update that improves the triggering above 1MHz.
Offline Hydrawerk
« Reply #104 on: May 02, 2015, 04:25:45 pm »
I found a schematic of HPS140i.
« Reply #105 on: May 02, 2015, 04:36:48 pm »
@Hydrawerk,
Great find. Thank you  :-+
Aurora
Offline R_G_B_
« Reply #106 on: May 02, 2015, 06:46:32 pm »
If only we could hack the firmware so that you could add single shot and other features this would make this handheld scope more useful.
Anu chance of this happening?
R_G_B
Offline R_G_B_
R_G_B
« Reply #108 on: May 02, 2015, 07:27:32 pm »
Velleman were very protective of their firmware last time I asked them about it.They also said they would not be releasing the schematics at that time as they "were not ready to do so with such a new design" (at the time I asked).  I had to send my units back to Velleman for their firmware upgrade and have another four heading that way soon. It would have been so much easier to reprogram the MCU myself with the new code but I do not know whether calibration is then needed.
This is the first truly technical information on the HPS140 I have seen to come out of Velleman.
Aurora
« Last Edit: May 02, 2015, 07:31:08 pm by Aurora »
Offline R_G_B_
« Reply #109 on: May 02, 2015, 07:37:08 pm »
Maybe they are planning on releasing another scope.
The last two portable scopes HPS10 and HPS40 had schematics released not sure if they released the schematic some time after these two products went to market or at the same time.
As for the firmware now theres a schematic maybe someone can reverse engineer it and add features.
The main MCU is a microchip DSPIC.  Is the firmware encrypted?
R_G_B
Offline Leafy
« Reply #110 on: March 25, 2020, 12:45:22 pm »
Ok I realize I'm bumping a thread from half a decade but this is probably the only concentration of HPS140 owners I'll find.
Can anyone with this thing measure the barrel connector on the charger so I can figure out what I need to buy to charge mine? This information seems like a huge secret.
« Reply #111 on: March 25, 2020, 12:51:09 pm »
The unit comes with a USB based boost converter that increases the USB 5V to 9V. So you need a 9V d.c. power supply.
I will dig out my unit today and see what current and polarity it requires.
Fraser
Offline Leafy
« Reply #112 on: March 25, 2020, 12:58:50 pm »
Thanks, I believe I saw somewhere that the polarity is swapped from a normal barrel plug charger, at worst I can open up the unit and figure that out.
« Reply #113 on: March 25, 2020, 01:51:08 pm »
Power adapter is 9V 200mA centre positive on a 3mm OD barrel plug.
Polarity confirmed as centre positive by multimeter test.
Fraser
Offline Leafy
« Reply #114 on: March 25, 2020, 01:52:32 pm »
Do you have the ID?
*Edit, looks like it better be 1.1mm or I'm shimming it anyways. Thanks a bunch.
For anyone else in this predicament.
https://www.mouser.com/ProductDetail/CUI-Devices/PP3-019?qs=sGAEpiMZZMtnOp%252BbbqA0023axwHuElQy2c5IhC1LWJ56KLiPljRvhA%3D%3D
https://www.mouser.com/ProductDetail/Phihong/PSM03A-090-R?qs=sGAEpiMZZMt5w6YCUaBPUYs%2Fw9Qhz%2FAu7NQ0q6hj7XA%3D
total will shipping was under $10
« Last Edit: March 25, 2020, 02:13:58 pm by Leafy »
« Reply #115 on: March 25, 2020, 02:32:56 pm »
Sadly I do not have the ID.
A 3mm OD normally has a 1.1mm ID though. Yer digital calliper confirms exactly 3mm OD on the barrel.
Fraser
