Author Topic: Velleman HPS140i miniature DSO - a thing of beauty or ugly duckling ?  (Read 74930 times)
Offline TheWelly888
Re: Velleman HPS140i miniature DSO - a thing of beauty or ugly duckling ?
« Reply #25 on: March 21, 2011, 07:30:25 pm »
The HPS140 also has the backlight supplied as standard. Why this was not the case with the HPS10 I will never understand. I fitted a backlit LCD panel to one of my HPS10's and it works well.
Thanks for the datasheet for the backlit LCD, I might consider fitting a backlit LCD but I might consider getting a HPS140i instead!  ;)
You can do anything with the right attitude and a hammer.
Online FraserTopic starter
« Reply #26 on: March 21, 2011, 07:39:16 pm »
A cheap and cheerful way to get light into an LCD display is 'side lighting' as found on old LCD watches   :)
For virtually no cost you could try adding some bright diffused LEDs to each side of the standard LCD panel and see if the lighting is adequate. Three each side should be enough. I have never done this on a large display but it is easily reversible and worth a try ?
Online Zero999
  • 0999
« Reply #27 on: March 21, 2011, 07:45:47 pm »
I believe the comment regarding using the scope whilst charging from a USB port MAY be due to the lack of galvanic isolation between BNC and charging port so a computer USB port could be exposed to damaging voltages.
Yes, that's what I meant. I would never dream they'd bother with isolating the input from the rest of the 'scope.
« Reply #28 on: March 21, 2011, 08:09:45 pm »
Hero999,
I was typing my message whilst you were posting yours and they crossed in cyberspace ;)
You were first to state the reason  ;D
Offline mikeselectricstuff
    • Mike's Electric Stuff
« Reply #29 on: March 22, 2011, 12:28:07 am »
OK folks teardown time : http://electricstuff.co.uk/velleman_hps140.html
No real surprises there. Pity about the crude battery management.
(Ignore original comments re. time measurememt - hidden in additional menu..!)
« Last Edit: March 22, 2011, 12:42:07 am by mikeselectricstuff »
Day Job: Mostly LEDs
Offline saturation
  • Doveryai, no proveryai
    • NIST
« Reply #30 on: March 22, 2011, 12:14:09 pm »
Great review, mike, shows how they managed to reduce costs as much as possible.  The only thing left to see is its actual frequency response.
The battery rests on the PCB with sponges; those sponges deteriorate in a few years but its easy to replace.  Looks like it could rattle sometime in the future and bump against the casing.  The HPS40 series have batteries cradled in their own plastic shell, firmly held down by the screw case, but enlarges the size much.  Practically however, not sure how either design is better drop proofed, the 140 has the sleeve to absorb some shock while the HPS40 has a better more rigid case.  The supplied carry bag gives it drop-shock proofing for transport though, and a container to stash the probes and an wall wart, if you have one.
Best Wishes,
 Saturation
« Reply #31 on: March 22, 2011, 01:42:50 pm »
will check this soon
yes - they should have used high-density foam, although the case isn't really rigid enough to be able to apply too much clamping pressure, so this may be the reason for the thin foam. Some double-sided sticky pads would probably be better.
« Reply #32 on: March 22, 2011, 11:10:51 pm »
A quick play with a signal generator reveals this unit has limited usefulness above 1MHz - abote this, trigger becomes jittery, and there are some aliasing issues. I have seen the auto-scale lock onto an alias, which can produce some rather bizarre trace displays!
« Reply #33 on: March 22, 2011, 11:45:33 pm »
Mike,
Thanks for doing the teardown and test for us.
Interesting findings. I presume you were presenting the unit with a square wave as if it's unhappy above 1MHz with a sine wave I would be really surprised. Thanks to your details of the ADC (ADC0801S040) we can see that the device was designed for video AD conversion and has an analogue bandwidth of around 10MHz with a Max sample rate of 40MHz. That may explain why it provides a decent enough image of 6MHz CCIR CCTV signals.
Most of my work is in the analogue domain with occasional journeys into the world of 1's and 0's so this little scope should be fine for me. Not so sure about it being useful in the world of fast microprocessors though.
I see your unit has the same capacitor mod as mine. I wasn't that impressed with the physical implementation of the mod but I suppose if it works OK it does the job well enough. It was nice to see the relay's present on the PCB. Like you, I find the absence of a managed charge circuit and any 'battery low' indication a disappointment. It doesn't cost very much to include such features these days.
All in all, I am very pleased with my purchase and have already used it several times as it is just as convenient as grabbing my multimeter off the desk, and so quick to use. The very compact size makes all the difference for me in terms of convenience. The serious stuff will still happen in the lab with my bench scopes but the little HPS140 has now ousted my UNI-T UT81B from it's perch as the 'grab & go' scope  :D
« Reply #34 on: March 23, 2011, 12:08:35 am »
Mike,
Nope. Sinewave. trigger jitter is the first problem you see. Amplitude starts nosediving around 6MHz.
Actual usefullness is always the ultimate test, but I think omission of frequency/period/RPM measurement was a major missed opportunity.
Offline saturation
    • NIST
« Reply #35 on: March 23, 2011, 09:46:58 am »
Ouch.  Sorry to hear, I was looking forward to this as potential replacement for my HPS40 should it get bricked.  Test waveform is sine wave > 1 MHz and up?  I'll post HPS40 screen grabs.
Aurora, Mike's quick test is another good reason to compare frequency response to the Uni-T 81.
Mike,
Best Wishes,
 Saturation
« Reply #36 on: March 23, 2011, 10:50:29 am »
Here's a vid showing response from 1-10MHz.
Offline saturation
    • NIST
« Reply #37 on: March 23, 2011, 11:15:14 am »
G'morning mike from NE USA.  You beat me to it!  You are fast.  That response is much like the HPS40, its not too bad.
I agree fully to 1 MHz, its at its best.  Between 1-4MHz, is 'ok', and above 4 MHz, you need to read between the lines. If I saw anything above 10 MHz, I better open the windows and make sure my glue containers are shut tight  ;D.   Given its 40 MHz clock and sampling rate, I limit its use to 4MHz and below.
Since the PIC MCU uses its internal oscillator, I think jitter is heavily part of the low internal clock stability, but above 4 MHz or so, the sampling rate increasingly plays havoc on waveform stability since its can't trigger at the right levels consistently.  Square waves are stable at 1~3 MHz, to suggest its able to lock in a bit better on step responses than sine.
Best Wishes,
 Saturation
« Reply #38 on: March 23, 2011, 11:49:17 am »
I don't think so, as if it was clock jitter you'd see waveshape distortion - the magnitude of the trigger jitter is way more than any visible distortion of the waveform - when frozen the waveform looks pretty uniform.
Assuming the triggering is done via a seperate path to the ADC signal processing, it's more likely some variable-latency issues and/or limited performance of the trigger hardware, which I assume is that LMV934.
« Reply #39 on: March 23, 2011, 05:35:49 pm »
Mike,
Regarding frequency and period measurement... did you mean dynamic or static measurement ? The HPS140 does offer frequency and period measurment of a static signal in the 'Hold' condition by use of the markers.
« Reply #40 on: March 23, 2011, 05:38:18 pm »
Mike,
Yes, but it would be so much nicer, and entirely feasible, to have it do automatic freq, period, pulsewidth, duty cycle, RPM  measurments as well for no extra hardware cost, which would make it so much more useful.
« Reply #41 on: March 23, 2011, 05:56:09 pm »
Agreed  :)
I have just run my HPS140 through the same test as you and can confirm mine bahaves in exactly the same manner. If I am totally honest I am disappointed with the triggering performance  :(  Lots of jitter above 1MHz. Using 'Hold' provides a clearer image but I expected the waveform distortion due to aliasing errors to cut in before triggering started to let go.
If I were writing a report on the HPS140, I would say 'could do better'.
I will have a quick look at how my UT-81B behaves and report back.
UPDATE:
A quick test of the UT-81 wiped the floor with the HPS-140..... ho hum  :(
I have an acceptable trigger stability on a sine wave being displayed at 12.8 MHz (yes 12.8MHz). There is some jitter but nowhere near as bad as on the HPS-140 at 2MHz ! The UT-81 is suffering attenuation at 12.8MHz of course but the display is stable enough for assessment.
I guess this either makes the UT-81B a good performer or the HPS140 a FAIL  :-[
More when I have time.
« Last Edit: March 23, 2011, 09:00:27 pm by Aurora »
« Reply #42 on: March 23, 2011, 07:14:35 pm »
I'm starting to think the HPS-140 has a design fault as the triggering is so unstable above 1MHz whereas the UT-81B is far more stable.
I have just completed some tests and pictures will follow. It is safe to say that the UT-81B is a far superior product in terms of it's trigger lock and bandwidth. I'm gutted  :(  I can tolerate compromise but this may be a step too far. An email to Velleman may be in order to ascertain how well they expect the unit to perform.
« Last Edit: March 23, 2011, 08:59:18 pm by Aurora »
« Reply #43 on: March 23, 2011, 08:32:18 pm »
Ok I quickly did a comparison between the HPS-140 and the UT-81B.
The test setup used a Grundig/Digimess FG100 20Mhz Function Generator (this uses a MAX038 core). The function generator was working into a 50 Ohm through termination then split using a common BNC T piece feeding the two oscilloscopes via 25cm RG58U patch cables. Both oscilloscopes should see the same signal but it is acknowledged that the T splitter is less than ideal in terms of impedances etc.
I presented the oscilloscopes with a square wave and photographed the displays at various frequencies. The results are shown in the pdf attachment. The 10MHz and 15 MHz signals were Sine waves and I was just interested to see how the UT-81B coped with the higher frequency signals.
With regard to jitter.... both oscilloscopes displayed very minor jitter at the lowest frequencies due to minor sampling point tolerances, The UT-81B maintained a stable and well triggered waveform display up to beyond 13MHz with jitter becoming an issue at 15MHz. The HPS-140 displayed minor waveform jitter at 1MHz and was becoming unstable at 2MHz, increasing to unacceptable jitter at 4 Mhz. HPS-140 triggering was lost at 5MHz.
Rise time measurement at 1MHz was not possible due to the limitation of the timebases (100nS/Div on UT-81B and 25nS/Div on HPS-140)
It would be fair to say that the HPS-140 is a compromise (compromised?) solution to achieve small size. It is for potential purchasers to decide if it is compromised to the extent that it loses credibility as a 40 MS/s 4MHz BW DSO. I shall be using mine for quick checks to ascertain the presence and level of various sub 4MHz signals. I am still disappointed at the trigger performance however, and shall be raising this with Velleman.
« Last Edit: March 23, 2011, 08:57:21 pm by Aurora »
Offline saturation
    • NIST
« Reply #44 on: March 23, 2011, 08:49:59 pm »
Wowza.  Thanks so much for doing these Aurora, Mike, and the commentaries too.  I keep thinking of the 140 as the same as 40 but there are differences, AFAIK.  Will duplicate your tests as you did and post my results.   Comments later.
Best Wishes,
 Saturation
« Reply #45 on: March 23, 2011, 11:22:57 pm »
The HPS-40 is a somewhat more complex circuit than the HPS-140 so I would expect better performance in terms of triggering.
I attach the schematic/Service manual for those interested.
Offline saturation
    • NIST
« Reply #46 on: March 24, 2011, 06:13:27 pm »
thanks Aurora for the calibration and maintenance manual; its one reason I got the Velleman is that I have access to repair data.  The 40 is 5Ms/s, not what is described in some of their literature and oversamples x8 for repetitive sampling.
I don't have the trigger problems you both describe well in this thread.  I'll post static photos later today of distorted waveforms at > 8 MHz, but synced and stably displayed.
Best Wishes,
 Saturation
Online Zero999
  • 0999
« Reply #47 on: March 24, 2011, 10:23:20 pm »
I received mine yesterday. I've still not got round to testing it. Oh well, it might not be up to the specs but I don't regret buying it, even if it's limited to only 2MHz. As far as I'm aware there are no hand held 'scopes which can work up to 2MHz on the market for that price and even a true RMS meter with that frequency range is expensive. It's still fine for audio and low speed PIC stuff. I'd only be pissed off if something better is available for the same price.
« Reply #48 on: March 24, 2011, 11:29:35 pm »
One thing that I have noticed about the jittery trigger. On my unit the jitter appears to be a sampling point variation on the waveform so I can press the hold button and the display shows a clean waveform, at leat up to 4MHz. I will have to do some more testing but life turned hectic real quick today so no time to 'play'.
I have decided that the unit is worth the money to me as it provides the portability I need, with adequate performance for the low feq work that I regularly do. I am often looking for noise on audio and power supply rails.
I will still contact Velleman via their forum as soon as I get a chance (www.velleman.be) and I suggest others do as well. Velleman have been helpful to me in the past and they may respond to our concerns regarding the trigger stability.
UPDATE:
I have raised the HPS-140 issues with Velleman on their support Forum. I await their response. I recommend others state their concerns on the same Forum topic if you wish to see the issues addressed.
Forum message is here:
http://forum.velleman.eu/viewtopic.php?f=9&t=5913
« Last Edit: March 25, 2011, 12:16:06 am by Aurora »
« Reply #49 on: March 25, 2011, 12:41:59 am »
Looks like it may be more of a software issue - did some probing around and found a couple of signals from the front-end to the PIC, and neither of these show any jitter :
BTW I also figured out why they reccommend not charging from USB while using - the power ground is NOT connected to signal ground.
The signal ground sits at about 2V above supply ground, presumably to simplify handling of negative inputs. Fortunately there is no smoke if the power and signal grounds are shorted, the trace just disappears.
