Author Topic: Vintage teardown- Weston 6000  (Read 4954 times)
Offline reagleTopic starter
    • KuzyaTech
« on: February 17, 2014, 07:17:29 pm »
More of a "first look and take pictures" rather than a full teardown and analysis, but it's pretty non-the-less:
http://kuzyatech.com/vintage-multimeter-weston-6000
If anybody has access to schematics, Weston-to-Normal parts mappings or the LCD glass- please let me know!
    • KuzyaTech
Re: Vintage teardown- Weston 6000
« Reply #1 on: April 26, 2014, 05:08:04 pm »
Just updated with a scan of the user manual.
Offline Vgkid
« Reply #2 on: April 26, 2014, 06:53:37 pm »
Did you ever figure out what the Weston marked ic's were?
« Reply #3 on: April 26, 2014, 07:11:28 pm »
Easy enough to work out a rough mapping for the LCD by simply tracing the ITO traces on the top of the glass  and tracing to the edge. It likely is a standard pinout, 28 pins says it likely is a standard 1888 display with a DP per segment and a single backplane. TRy looking online for 1888 LCD displays with a single side connection, it is likely to be a similar pinout as the ITO can not handle any other layout easily.
    • KuzyaTech
« Reply #4 on: April 26, 2014, 08:54:37 pm »
Yep, working on that- it's a pretty standard pinout
    • KuzyaTech
« Reply #5 on: April 26, 2014, 08:56:21 pm »
Not yet. They do site a patent describing how they do ADC conversions, so the chips could could potentially be custom. The display driver I initially though was the standard meter chip, but it's definitely not.
