Author Topic: what is the difference between a rigol DL3021 and the DL3021A  (Read 4466 times)
Offline SteveWS5WTopic starter
I have seen the spec sheet but nothing is jumping out?
Steve
Offline H.O
Re: what is the difference between a rigol DL3021 and the DL3021A
« Reply #1 on: July 17, 2017, 06:48:56 am »
There are some differences.... The A model can do higher frequency, higher slewrate, has higher current readback resolution and wider range on resistance readback. It comes with LAN interface and digital I/O as standard.
As far as I understand it's all software options and the A-model has those installed by default.
Making the LAN interface optional is a big step in the wrong direction IMHO.
Offline simone.pignatti
« Reply #2 on: July 17, 2017, 10:40:43 am »
I have done these 2 tables which may help
Technical Support
Offline MotoDan
« Reply #3 on: October 18, 2017, 05:16:37 pm »
The DL3021A also has a color screen.
Offline Pinkus
« Reply #4 on: October 18, 2017, 10:20:49 pm »
they both have the same color screen, but the DL3021 is using (almost) only one color.
It is the same as with the DP832 and DP832a.
Unfortunately it is not possible (well it probably is, but nobody was able to yet) to hack the DP832 so it thinks it is a DP832a.
