The DER DE 5000 LCR meter can readily measure what you have asked for when in the auto mode, however should you need to use the sort feature then you first need to select the particular mode either L, C or R and set the tolerances.
The unit can be ordered with the USB cable and obviously the software, I don't have the USB interface although I did download the software and others have looked at the serial decoding which I think from memory is done.
There are dozens of threads on both this and other LCR meters on the forum.
