Author Topic: Which audio testgenerator is this?  (Read 2184 times)
Offline KjeltTopic starter
« on: May 05, 2016, 07:19:09 pm »
Interesting youtube movie from dutch DAC builder Metrum (unfortunately only dutch).
But which instrument he has is this?
Offline tautech
Re: Which audio testgenerator is this?
« Reply #1 on: May 05, 2016, 07:28:58 pm »
At first glance and going on the colour scheme it looks like a Phillips but a name is partly visible and apparently starts with A.
Did Phillips do any rebrands?
Avid Rabid Hobbyist
Offline Floyo
« Reply #2 on: May 05, 2016, 07:31:50 pm »
Its a dScope audio analyzer.
http://www.prismsound.com/test_measure/products_subs/dscope/dscope_home.php
A couple of brands make these, Audio Precision probably being the most well known, but dScope and Rohde and Schwarz make/made them too.
Expensive bits of kit which can test almost everything audio, both the digital and analog domain.
The following users thanked this post: kripton2035, Kjelt
Offline Floyo
« Reply #3 on: May 05, 2016, 08:21:09 pm »
Also, for the non Dutch speakers amongst us, in the first couple of minutes the guy talkes about how adding lowpass filters to get rid of the images caused by nyquist are bad because they cause pre and post ringing artefacts on impulse type signals, and proposes that making use of the natural frequency roll off of the entire signal chain including the human ear and the speakers will accomplish the same goal without these issues. He also mentions a whitepaper, of which an English version resides here : http://www.metrum-acoustics.com/Design%20Philosophy%20Metrum%20Acoustics.pdf
I for one wonder what is going to be said about intermodulation distortions etc, somehow this idea intuitively seems a bit "off", but its interesting nonetheless.
Edit: Watched the whole thing now, not a word was mentioned about IMD etc, but here follows a quick summary.
First they talk about how dithering gets a 16 bit CD from 96 to 120db of dynamic range.
They made their own dac implemented with 2 12 bit r2r ladders and an fpga, both dacs are summed in the analog domain to supress the noise of the switches in the dac, this gets them to 20 bits. They needed to roll their own chips since other non-oversampling chips were end-of-life
Next up they refer to Nelson Pass's research that states "faster circuits sound better", meaning higher bandwidth. Their resistor ladder does 50Mhz sampling rate if they clock the data in parallel, but using the built in shift register is slower, since 44.1K is good enough for audio anyway. It is mentioned that SACDs do sound a bit better because 24Bit 96K, but that its mostly the better mastering process.
Other manufacturers can buy their DAC modules, you only need to stuff in i2s and power to get out audio.
The next hurdle they have to overcome is to make the 20bit dac module more affordable and
bring the price down from 5K to 1K. Its mentioned in passing that a lot of info about DACs on the web is misleading, and 24 bit converters are mostly a marketing driven thing, but they think some barely discernible difference is still audible.
The last interesting technical bit is about the noise floor of single ended versus symmetrical connections. The single ended scope plot shows large distortion at -90dbFS, whilst the symmetrical signal still looks fine until -120dbFS. The distortion products on the single ended connection are basicallly 50Hz mains and its harmonics.
The video ends with a short factory tour, standard affair, p&p and reflow.
Ok, I hope that whole story gives the the non-dutch speakers a bit of insight into what is going on in the video. Although there is no quackery going on, and most of the experiments done make total sense, relatively little time is given on how leaving out the anti-aliasing filters on the DAC does not cause any issues of its own, which is a bit disappointing.
« Last Edit: May 05, 2016, 09:05:52 pm by Floyo »
The following users thanked this post: Kjelt
« Reply #4 on: May 05, 2016, 10:15:29 pm »
Thanks for id'ing the device and the summary for non dutch users  :-+
Offline Loboscope
« Reply #5 on: May 05, 2016, 10:17:09 pm »
Thank you for the translation!
As far as I know, the guys who prefer the ¨old-style¨ DAC-technique because it did not use oversampling (simply, it did not exist in these times) and by this they would deliver a better sound, belong to the ¨Audiophoolery-Community¨?
Greetings, Jürgen
Online The Soulman
  • The sky is the limit!
« Reply #6 on: May 06, 2016, 12:24:41 am »
Greetings, Jürgen
Nah, oversampling was invented by Philips to make their freshly developed 14bit tda1540 dac chip play the 16 bit 44.1khz CD standard agreed with sony for the first cd players.
It did came in handy for error correction so it stayed ever since (at least that is my version of the story..)
Been playing around a lot in the past with (16 bit) tda1541 and tda1543 in non oversampling mode, parallel a couple even better.
It isn't phoolery it's a bandwidth thing, or actually slewrate to be more precise, leaving out the low pass filter (reducing phase distortion) does put higher
demands on every component that follows to avoid harmonic distortion.
I'm a big fan of non oversampling, but never heard of this company..
« Reply #7 on: May 06, 2016, 07:40:18 am »
I am also a fan of NOS dacs, don,t know why, but a true bit 20bit dac seems to sound better to me than those newer marketing 32 bits dacs.
Offline Marco
« Reply #8 on: May 06, 2016, 08:26:46 am »
Bit late to worry about it, the low pass filters during recording did the same thing.
