With -40 dBm into your 50 ohm loop you should have, -40 dBm + 107 (dBm -> dBuV) - 34 dB_ohms = 33 dBuA.
- Herb
Thanks for challenging me on my "calculations", I indeed made some incorrect assumtions above. I am now not in the lab, but convinced myself the value read on the spectrum analyzer is correct for a 1V/A probe. I used the following table for this:
http://wera.cen.uni-hamburg.de/DBM.shtmlInput into load:
-10 dBm (0 dBm output on the siggen with 10 dBm attenuator)
=> 70.7mVrms => 1.41mArms (for a 50 ohm load)
1.41mArms in a probe with an expected output of 1V/A
=> 1.41mVrms output => -44dBrms on spectrum analyzer
And this is exactly the value I am seeing in the passband (@10MHz)
What still strikes me as quite strange, is that the probe continues outputting quite a strong signal up untill almost 100Mhz. After I posted the above I also ran a simular test up until 500Mhz, but I unsure how to interprete this result.
