Here is the latest on my progress using the LAN interface. I connected an Ethernet cable from the scope to my router (see image). The image also shows my overall setup.
I followed the instructions and setup the scope for DHCP enabled. I wrote down the IP address 192.168.1.13 as I need it later.
I installed the software NI Visa and also visa530full.exe, no problems with the install.
When I run EasyscopeX and try to Add Device, when prompted I enter the IP listed above. A dialog box opens and displays: The device can not be open. Please confirm the IP address.
I then ran NI MAX (Measurement and Automation Explorer, it also does not see my device.
If I go into my Netgear router, and look for connected devices, the router does list my scope under wired devices. The device name is listed as "unknown".
I am sure the problem is operator error but I am out of ideas
