Author Topic: Yellow sticker?  (Read 10448 times)
Offline Paul Moir
Re: Yellow sticker?
« Reply #25 on: April 22, 2013, 02:36:48 am »
Peanut butter is also shockingly effective.  I suspect modern, trans fat free (hydrogenated vegetable oil free), have only made it more so.  Wouldn't bother with "natural" stuff that separates.
« Last Edit: April 22, 2013, 02:42:54 am by Paul Moir »
Offline pickle9000
Re: Yellow sticker?
« Reply #26 on: April 22, 2013, 03:20:33 am »
Most drug stores sell adhesive tape remover, first aid section or over the counter. It's to remove the sticky stuff on band aids. Whatever you use test it first.
http://www.amazon.com/Dynarex-Adhesive-Tape-Remover-Pad/dp/B000OPZ4WA
Offline ddavidebor
    • Smartbox AT
Yellow sticker?
« Reply #27 on: April 22, 2013, 04:57:08 am »
It can and I have seen it. It depends on the plastic. it is better to start with the least aggressive solvents and work up in power. Actually the first thing to use would be the cooking oil, then lighter fluid, then alcohol.
LIGHTER FLUID?
Have you drink too much solvent dude?
Lighter fluid is a damn strong solvent, it's petroleum, it MELT plastic!
lighter fluid (in Canada) is usually butane, not quite sure about why the strong reaction. alkanes aren't exactly uncommon solvents.
I would think that propan-2-ol would probably be the best choice. Most "rugged"/durable plastics are resistant(ish) to it and I've never found a label or label-adhesive residue that I couldn't remove with it.
No, it's rafined oil. And incredibly similar to paint solvent. And in fact it melt plastic (cheap crap zippo).
Butane is a gas, propane also. How you can use it?
David - Professional Engineer - Medical Devices and Tablet Computers at Smartbox AT
Side businesses: Altium Industry Expert writer, http://fermium.ltd.uk (Scientific Equiment), http://chinesecleavers.co.uk (Cutlery),
Offline ddavidebor
    • Smartbox AT
Yellow sticker?
« Reply #28 on: April 22, 2013, 05:00:38 am »
Oh god, tank to provide someone with some salt in his head instead of hp destroyer and plastic melter.
Offline Lightages
  • Canadian po
Re: Yellow sticker?
« Reply #29 on: April 22, 2013, 05:15:03 am »
LIGHTER FLUID?
Oh yeah! Lighter fluid martinis!
Actually you might be right about this on plastic. I will have to refresh my memory by trying it on something again. I do use it all the time on painted metals to remove sticker residue. I would not take my "advice" until I check it again.
Offline ddavidebor
    • Smartbox AT
Yellow sticker?
« Reply #30 on: April 22, 2013, 05:41:03 am »
So you're a lucky men! Hp plastic is bulletproof, paint also...
Offline KJDS
    • my website holding page
Re: Yellow sticker?
« Reply #31 on: April 22, 2013, 07:41:45 am »
If you want to get the smell of the Australian bush then eucalyptus oil  works just as well.
Try Youngs 303, the aftershave for real men
Offline poodyp
Re: Yellow sticker?
« Reply #32 on: April 22, 2013, 02:48:14 pm »
Canadian space agency
Canadian Standards Association. If it were from a space agency I'd probably leave the sticker, though.
Aw, that kinda makes me sad then. I do actually have a piece of gear with a Lockheed Martin sticker on it. That made me kinda happy.
Offline DaveTopic starter
  • Country: si
  • I like to measure things.
Re: Yellow sticker?
« Reply #33 on: April 23, 2013, 11:28:54 pm »
Thanks for all the replies.
I would have kept the sticker, if it's corners wouldn't be all torn, dirty and crusty - so I removed it. As I first planned, I attacked it with rubbing alcohol (ethyl alcohol with smelly pink additives). It worked like a charm, the sticker peeled right off. There was no damage to the plastic whatsoever.
The meter's front was covered with nasty glue residue, that also came off beautifully with rubbing alcohol.
The real pain in the a** was the "calibration void if torn" sticker over the CAL switch on the front. I spent at least 20 minutes slowly chipping the pieces, as the sticker was so fragile, it was impossible to remove otherwise. :scared: Alcohol didn't help at all in this case. ;D
Anyhow, the meter looks great now, I just need to find it some feet (the unit was probably rack mounted before - the side screw covers are missing as well).
I have attached the picture of the area, where the two stickers used to reside. Squeaky clean now. :)
<fellbuendel> it's arduino, you're not supposed to know anything about what you're doing
<fellbuendel> if you knew, you wouldn't be using it
