Hi all,
Been lurking here trawling various posts for a while as I've been considering a thermal imaging setup to try some things with. It would mainly be used for imaging from an almost photographic perspective, including moving targets, and some spotlighting trips for tracking down mammals/birds at night without flushing them by using my spotlighting gear. Because of this I think a 640 pixel ~25-30+Hz model would be most appropriate to cover the bases. I'm also looking for a system with the capability to change lenses reasonably easily. Budget would preferably be under $5,000 as a ballpark figure, still trying to get the man maths to add up that on though...!
The two systems which have caught my eye so far are the Therm-App Pro with the 19mm default lens and the optional 35mm lens for a bit more reach and the Thermal Expert V1, again with the default 19mm lens and optional 35mm lens. Down the track I might look at adding a 75mm or 100mm option depending on what is available. Did anyone have any experience with either of the cameras individually, or even a comparison between them? Information and reviews seem rather scarce online for the two units outside of example images (including some of the very impressive shots floating around on here!). The Therm-App Pro struck me as a more polished unit, with the mounting system looking more robust and better app selection for imaging directly from a phone (namely ThermViewer). That said the Thermal Expert also seems capable enough looking at the videos on their Youtube channel (), and would likely come in significantly cheaper based on the limited info I can find locally.
I've had a bit of a look at some of the thermal cores available, particularly the Flir Boson range as these come with a good range of lenses, haven't seen anything about them being interchangeable though. These would also need a bit more setup work to provide a handheld imaging solution from what I can determine. Not having a lot of experience with this sort of stuff I haven't really been able to make any headway regarding potential solutions using a such a setup.
Hopefully most (or at least some) of that made sense, thanks in advance for any guidance provided!
