Finally got my Therm-App Standard (384x288 @ 9Hz), and has great quality. I must say that the optics are outstanding. Comes with 19mm lenses, which have quite a lot of zoom. If you try to see things inside a room on your house you must stick to the opposite wall as away as possible because the field of view is noticeable narrow for interior. That should be great for exteriors, did not test yet.
Also, it has manual focus, rotating the knurled lens housing with your hand. Really nice.
There's an annoyance though, the official android app doesn't allow to set custom temperature range, only auto-range all the time.
There a third-party one, which allows to lock the range, but you can't just enter the maximum and minimum values there, only you click a lock icon and locks the current values, so you have kind of move around until the current maximum and minimum values fit you. The third-party app doesn't have several coloring options, only two different grey scales.
These are the microUSB to USB-C adapters recommended by the brand:
Therm-App USB Type-C phonesHowever I recommend buying directly a cable with both connectors, for USB-C phones:
flickr adapter discussion4" Right Angle Micro USB to Type C OTG Cable for Portable Digital DAC Amplifier
