Author Topic: BMW automotive thermal imaging night vision camera  (Read 6024 times)
Offline xmjackyTopic starter
  • Country: cn
« on: May 23, 2017, 12:07:37 pm »
I also have a BMW thermal imaging camera, the 2nd Gen BMW system,4 wire interface,and the research work has made little progress
1, camera interface definition.(1.JPG)
2, the decoder using MAX9260, as long as the build simple circuit can output RGB encoding 16bit, the logic analyzer results, video decoding is correct, but the camera does not output pixel data, should be the protection mechanism of the problem.
3, the use of PC through the MAX9260 to send the camera command (232, RX/TX), in some baud rate can receive replies, but I do not have the exact command, can not let the camera work properly.
If you have a BMW car or rent a car, you can grab data with a simple tool(logical analyzer or serial port tool), you can remove the protection mechanism.You can connect the line to the MAX9260 pin to read the data.
Wiring mode is as follows,The pins with green highlights have function, others are left vacant.
  • Country: cn
Re: BMW automotive thermal imaging night vision camera
« Reply #1 on: May 23, 2017, 12:17:59 pm »
Hope that more people join the crack job
  • Country: cn
« Reply #2 on: May 24, 2017, 04:44:15 am »
In addition to serial communication, there may be I2C communication, but it is easy to read and analyze data
Offline boywai
« Reply #3 on: September 12, 2017, 10:42:46 am »
I am also a Chinese friend can add a WeChat together to explore   ?boyliuhaoyue
Offline boywai
« Reply #4 on: September 12, 2017, 10:44:50 am »
I am also a Chinese friend can add a WeChat together to explore    boyliuhaoyue
  • Country: cn
« Reply #5 on: September 13, 2017, 06:58:35 am »
OK
Offline lefedor
  • Country: ru
« Reply #6 on: September 14, 2017, 09:47:01 pm »
Do You have NightVIsion ECU from the very the same car?
Offline XDA
  • Country: ru
« Reply #7 on: July 18, 2018, 11:12:17 pm »
Any news about hack enable command for camera?
  • Country: cn
« Reply #8 on: July 31, 2018, 12:22:36 pm »
It seems that no one has a try.
I bought  new BMW 5 series(G38), but unfortunately the new 5 series has no night vision options.
« Last Edit: July 31, 2018, 12:29:53 pm by xmjacky »
Offline ir.ukrm
  • Country: ua
« Reply #9 on: July 26, 2019, 04:58:48 pm »
I think the one who hacks this camera will get the Nobel Prize.  |O :-DD
