Author Topic: Enhance a old FLIR ThermaCAM E45  (Read 1871 times)
Offline joe-cTopic starter
    • Joe-c.de
« on: September 02, 2018, 11:08:48 am »
Hello,
time to talk about the old Thermacam E45 (and similar old Cameras from FLIR).
The camera has default a USB Network connection, but this was only used to simulate a Drive with the Images.
With a Network tool I found the default IP from the Camera...
192.168.66.66
And with Ping scan of this Area I found 2 accessible IPs:
192.168.66.66
192.168.66.65
The Second connection don’t refuse a telnet connection and give a command line access like RS232 connection.
Additional it have a FTP Access, but this don’t support the “LIST” command, therefore it don’t work with Filezilla.
In the last Thermovision is a "new" sub-window called "Camera Commander: FLIR".
with a active Network connection its possible to download the system files.
  • goto Tab:Setup and select the option "Old: Thermacam E45 Mode", this is necessary because the Resource tree and the FTP works a bit different.
  • goto Tab FTP and enter the name of your Camera in the field "CameraName"
  • klick on "full dump" and wait until all data from the camera was downloaded
  • Open the folder from the camera with "open Folder"
  • ...do your changes...change logo, add color palette files, and so on...
  • klick on the folder in the tree you want to upload a file and select "upload" from mouse context menu (right click)
in the system/ are some *.reg files, they need to be open with notepad++ or other text editor.
i will attach my firmware stuff. i just removed a "system/matrix.elf" file with 4MB, i beleve the other files are more interesting.
Freeware Thermal Analysis Software: ThermoVision_Joe-C
Some Thermal cameras: Kameras
The following users thanked this post: radioorizont
Offline Fraser
Re: Enhance a old FLIR ThermaCAM E45
« Reply #1 on: September 02, 2018, 11:56:00 am »
Excellent work Joe-C
I love seeing how you smart software guys burrow into operating systems and firmware :)
This is the sort of experimentation I want to do on my old FLIR PM series cameras. I shall have to find the time to play with their file systems.
Fraser
« Last Edit: September 02, 2018, 02:35:07 pm by Fraser »
