This is the FLIR A65 compact with 13mm lens. It has been superceded by the Flir A65SC which uses the same core (I believe) but with a larger lens shroud.
Based on the Flir Tau2 core, it's nothing more than a Tau2 core plugged into a customized Pleora GigE Vision board, targeted at industrial automation and lab applications.
The converter runs a EP3C25 with 128mbit DDR2, with a 5V buck supply to make use of the 48V PoE supply.
The data format at the connector (just a 50pin Hirose) is documented and it's very possible to stick an FPGA, framebuffer and LCD on this thing and turn it into a standalone camera. However, too many projects... Digital IO connector used for sync was blown, but of no consequence for my applications.
While it's very capable, with 640x512 resolution it puts all low cost sensors to shame (and for the price rightly it should) at a nice fluid 30hz refresh, it is technically categorized as "fixed focus" because its focus adjustment takes a special tool and a not insignificant amount of wrenching, trial and error.
$70 later, we have the special FLIR-blessed CNC aluminum ring that inserts into the objective holder:
Using FLIR Tools, we have a very basic control of the camera (but not too much, because that would cost money). One gripe is that while you can save radiometric JPEGs, there is no way to export the image to a lossless format - so you are stuck with horribly quantized JPEGs, and with all the reds in the Iron palette, we're talking block city. Workaround for now is to screenshot the tool itself.
The next step was to make it portable. A PoE injector is required to feed the camera with 48V, so I picked up a 12volt Li-Ion battery bank, wired in a boost converter for 46V, and combined with my laptop, I can now go anywhere.
Flir Tools+ costs $300 and is necessary to record video - however, it only records at about 7-8fps regardless of the camera's actual rate. Even worse, it has no concept of frame deltas or time, so the Flir SEQ format is not usable as any sort of video recording medium (only for event logging).
With FLIR's own tools out of the picture, I got the Pleora SDK and modified a sample program to let me record to x264 at the full 30hz.
Of course, what better than to go driving?
In the parking garage it's easy to tell which cars have been recently moved:
Better results could be obtained from fiddling with the Tau2 core directly and enabling some additiona postprocessing - the firmware supports extra edge chancements and contrast enhancements which are good for use as night vision or security purposes. But here I am just running in raw radiometric mode.
