After a couple of flawless years using my G2 with the fantastic Thermal Camera+ app, I decided to try out the latest iteration of FLIR's own app.
This is where an extremely annoying problem has occured on my FLIR one now.
Ever since I ran the FLIR one app my FLIR one G2 now has developed a problem where it would retain a ghost thermal image until it's next recalibration.
So when it calibrates for the first time it 'burns' in an image and it ghosts while you move around until next calibration, and then that instantaneous image is also 'burnt' in and so on and so forth.
It seems to be a firmware problem it seems I'm guessing because it happens on both the thermal camera+ app and FLIR's own app now.
I'm unsure how to rectify this, I've deleted the FLIR app and restarted the phone, but not sure what to do now.
The included pictures is the hardware and firmware versions of my FLIR one G2 and an example picture.
In the picture is of some houses, you can see the rooftops are still on the image as I've reframed a little bit and look the photo.
