Chanc3,
Its your lucky day. I own three PM695's and two PM570's
Mine are all NTSC and please be aware that the viewfinders are fixed on NTSC. I was not aware that the cameras would respond to a command to change standards. Very interesting news.
With regard to working on these cameras, I have been inside all of them and they are relatively easy to work on. The case is held together with IIRC four screws and opens in a clam shell fashion to provide access in order to disconnect the ribbon cables between boards.
When the RTC battery is at the end of its life you will lose the time stamping and this is a sure indicator that it is time to fit either a new RTC or battery. My PM570's use the Dallas DL1643L RTC with non user changeable battery (you can change it though
) The battery is a tiny lithium button IIRC something like a tagged 1216 but I will need to check. The later cameras like the 695 use the Dallas DL1643P PowerCap series and these are designed to have their batteries changed so you just buy a new PowerCap or solder a tagged lithium cell into the old one. I bought a new cap as it contains the battery and clock crystal. It is not potted. I can provide more detail tomorrow but I am on my way to bed so it will need to wait.
For info, I also have three of the original FLIR remote controls. I opened one and was surprised at the technology within. A full embedded computer and S-Video to Composite Video converter
No wonder they are so expensive ! Overkill ? Built like a tank as well.
I purchased an AV RS232 remote commander that can be programmed with RS232 command strings. It is designed to control Projectors via RS232 but I am hoping it will also command the FLIR cameras as I have the command set. A project for another day though. My RS232 commander is the Extron MLC52. I was lucky and picked it up new for $30.
http://www.extron.com/product/product.aspx?id=mlc52rsWith regard to assistance from FLIR. I regret that there is little chance of that. I contacted virtually every service agent in the world trying to get any technical information on the PM series cameras. I met a brick wall in all but one case. And even then the tech was severely constrained by an NDA and ITAR regulations. He was able to confirm that the cameras are very reliable, built like a battleship and well worth maintaining in service
He also pointed me towards a likely cause of a fault on one of my PM570's. The service centres board change only, and then calibrate. I reverse engineered the CPU board on the PM570...... not an easy task and basically it turns out to be little more than a standard MC68340 embedded computer. I used an old Atari ST 520 computer to learn about the MC68000 and read lots of books on repairing embedded computers. I later proved that the fault did not lye on that PCB
I now know quite a lot about the guts of these cameras though
You may be interested to hear that the high temperature option filter/attenuator is fitted inside all the cameras, complete with actuator motor and mechanism. It is disabled only in software.
The CPU pcb has TWO RS232 ports on it. One for user access that goes to the Lemo 310 connector and one for Service use. Both are true RS232 from a dedicated level changer chip, and not TTL.
I will dig out some pictures of the internals tomorrow for you. Please PM me you email address.
As a final comment....these cameras were very expensive when new and are still expensive to have repaired. As the FLIR Tech told me....if you buy Mercedes quality, you pay Mercedes spares prices
IIRC the PM570 CPU pcb was $4000 + labour + calibration (essential) I think it totalled around $5000.
