Author Topic: FLUKE TiR2,TiR3,TiR4, Ti40,Ti45,Ti50,Ti55  (Read 3234 times)
Offline MedMax
  • Country: at
« on: June 20, 2017, 01:29:20 am »
I solved now the power supply issues on my Ti45 thermal camera.  :D :D
But now I need the content of the "internal SD-card" to boot the system up.
( I got the camera without the SD-card ..... |O  )
Can somebody please help here ???
Thanks
Offline Chanc3
Re: FLUKE TiR2,TiR3,TiR4, Ti40,Ti45,Ti50,Ti55
« Reply #1 on: June 20, 2017, 01:42:43 am »
I believe I have the files somewhere from when I had to replace a blown tantalum capacitor. Let me have a look. I assume it's for the SD card in the image attached?
The following users thanked this post: MedMax
Offline Chanc3
« Reply #2 on: June 20, 2017, 01:47:25 am »
I have attached what I think are the files I took off that internal SD card. This was back in 2015, so I don't know if this is all of the files. It is from a TiR3 I fixed.
« Last Edit: June 20, 2017, 01:56:18 am by Chanc3 »
Offline Chanc3
« Reply #3 on: June 21, 2017, 09:47:17 pm »
Did this work?
Offline MedMax
  • Country: at
« Reply #4 on: June 24, 2017, 12:24:42 am »
Hi Chanc3
First of all  BIG THANKS for your help.    :) :)
I just copied the files on a SD-Drive an tired it on my Hardware.
unfortunately it did not work,.....
Do you possibly know if I should see any  "boot activity on the screen" without the SD-Card.
Do I need a WIN-CE image on the SD-Card ???
Would be great if somebody can answer !
KR  Max
Online Fraser
« Reply #5 on: June 24, 2017, 01:05:06 am »
In your position I would ask FLUKE support if the SD card is available pre-programmed as a spare part. You could also ask if its presence is required for the camera to boot. FLUKE can be quite helpful if you get the right tech answering your questions.
Fraser
Offline MedMax
  • Country: at
« Reply #6 on: July 03, 2017, 05:31:34 pm »
I tried it at the Fluke support, but it seems, that I didn't get the right tech support, to help me. ... :-//
Offline Electro Detective
« Reply #7 on: July 03, 2017, 06:47:59 pm »
Keep trying, they can't all be bad hair day phone gods
Offline Chanc3
« Reply #8 on: July 05, 2017, 07:35:08 am »
Try reaching out to someone on LinkedIn
Sent from my iPad using Tapatalk
Online Fraser
« Reply #9 on: July 05, 2017, 08:06:35 am »
An issue that you may run into is the fact that FLUKE do not actually make the Thermal Cameras. They bought in the  technology and also bought Raytek.
In such cases it can be hard to find the right person within a large organisation who has the required knowledge to help. With 'bought in' technology it is often not possible to obtain internal spare parts. I have a suspicion the Ti45 was a 'bought in' model.
Fraser
Offline MedMax
  • Country: at
« Reply #10 on: September 14, 2017, 10:06:49 pm »
Thanks all so far,
can anyone give me the the original “Fluke part #” of this SD-Card which I need for the TI-45
that I can try to get it via the original FLUKE service !  :-//
THANKS !!   Max
Offline ali
  • Country: ir
« Reply #11 on: November 28, 2017, 08:04:03 pm »
i have the SD card content and i need part number of U7!
Offline ali
  • Country: ir
« Reply #12 on: November 28, 2017, 08:36:34 pm »
this file is true!
Online Fraser
« Reply #13 on: November 28, 2017, 10:17:55 pm »
Good work Ali,
Hopefully Medmax can return the favour with the U7 identity information you need  :-+
Fraser
The following users thanked this post: ali
Offline MedMax
  • Country: at
« Reply #14 on: November 29, 2017, 07:24:26 pm »
Hi Ali,
did a short look yesterday into the electronic to identify the U7.
I found there the Marking AAY on the chip.
Then I found the following types with marking AAY in my SMD Marking list.
I hope this helps !!
( .... had no futher time to check the SD-content, will give you feedback on that later !! )
KR  Max
Offline ali
  • Country: ir
« Reply #15 on: November 29, 2017, 07:27:31 pm »
very very thank you! :-+ :-+
Offline MedMax
  • Country: at
« Reply #16 on: November 30, 2017, 08:19:44 pm »
Hi Ali
Here the requested PIC of the U7 orientation !
Offline ali
  • Country: ir
« Reply #17 on: December 02, 2017, 05:42:47 pm »
thank you MedMax
Offline mai pham
  • Country: vn
« Reply #18 on: March 31, 2018, 04:42:24 pm »
Dear MedMax. Did you repaired your camera? Does it working now? Thanks
Offline MedMax
  • Country: at
« Reply #19 on: March 31, 2018, 07:47:07 pm »
Dear mai pham,
yes,
after several deep investigations in the electronic, i got it repaired !
KR Max
Online Fraser
« Reply #20 on: April 02, 2018, 12:47:54 am »
I saw a faulty camera like yours on eBay a while back and thought you had given up on it :) It was a Ti55 model though and sadly missing its lens :(
https://www.ebay.com/itm/Fluke-TI55-Infrared-Thermal-camera-/282863249260?hash=item41dbf6a76c%3Ag%3AKFQAAOSwUYNaCVeR&nma=true&si=CEX9wf1958HX5IV1VDEYPMaA1V4%253D&orig_cvip=true&rt=nc&_trksid=p2047675.l2557
Glad you managed to get it repaired. Did the repair sheet say what they did to it ? Enjoy your camera :)
Fraser
« Last Edit: April 02, 2018, 12:49:54 am by Fraser »
