Author Topic: Hmmm. There's a red LED glowing *inside* my E30bx. What's up wiith that?  (Read 1111 times)
Offline cvancTopic starter
It seems to glow even when the camera is turned off.  I can see it if I look into the (empty) memory card slot.  Any ideas what it means?  Thanks.
Offline Chanc3
The camera isn't technically off when you hold the power button, it just puts it into standby mode. You have to do a battery pull to fully turn it off.
Offline Bud
In Ex series holding the power button for 4-6 sec will turn the camera off.
Offline MyThermalWorld
  • Country: no
    • Palette Generator
This is for all Exx cameras I have used. But after 6 hours standby, it turns itself completely off.
Sent from my iPhone using Tapatalk
Offline Fraser
As already stated, the LED remains illuminated when in standby. The camera automatically drops into the 'OFF' state from standby after a set period of time and the LED is extinguished. The camera can be forced to 'OFF' by holding the power button down.
The ix and Ex series have the same LED present in standby.
Fraser
« Last Edit: March 31, 2018, 12:44:14 pm by Fraser »
