To Download the Images you can just use FTP.
You can download my Ex-Tools, to use the available functions over Telnet.
one of the Functions will change the USB Mode, there you can choose MSD.
Connect -> goto Tab:Setup 3 -> goto USB Mode and choose: MSD
Thanks for the advice joe-c, I tried your software but no luck. I can connect to the camera and communicate with it, but for some reason I cannot set USB mode.
Railrun - secret menu button worked, but it only displayed firmware versions and component details. Nothing to change the USB mode
I do have a copy of the files from a working InfraCAM - is there a way I can compare them easily to find the missing settings/files? Obviously I cannot do a complete copy over, as it'll need it's original calibration files, but if there is a file somewhere that contains connection details, I could just copy that?
Worst case, I'll hack it to enable the hidden SD card and use that instead.
