According to
http://www.trexenterprises.com/Pages/Products%20and%20Services/Sensors/security.html not only are um waves emitted in blackbody radiation, but mm waves are also emitted in sufficient quantities, allowing for mm wave cameras to be used passively for thermal imaging purposes, rather than an active imaging as most microwave systems require. This means there is no need for an emitter near the receiver like is required for RADAR. In the example used at that website, mm waves emitted from a warm human body will easily pass through clothing, but be blocked by a gun or other metal object the person is smuggling, allowing that person to be stopped before they can get on an airplane.
I had always assumed that THz and mm waves were so much longer than um waves typically used with thermal imaging, that the natural blackbody emission of these wavelengths would simply be too weak to detect, preventing passive imaging at these wavelengths. I always thought that these wavelengths would require an emitter pointed at the target, and that the receiver would pick up the reflected signal, just like with RADAR. But that above mentioned website seems to suggest that mm waves are emitted strongly enough, just from blackbody radiation, that they can be detected and used for passive imaging.
Anybody here have an idea how that actually works? There's not too many technical details about the system used on that website (probably proprietary trade secrets or something).
