Author Topic: Keysight U5855A TrueIR thermal imager  (Read 93150 times)
Offline Kilrah
Re: Keysight U5855A TrueIR thermal imager
« Reply #150 on: April 27, 2017, 05:52:02 pm »
If someone wonders here's the polarity of the battery connections.
Note that it draws 7mA when off  :bullshit: so don't leave your battery in when unused. So much for my easy "solder it in and forget it" solution  :rant:
Offline onesixright
« Reply #151 on: April 27, 2017, 06:06:33 pm »
Any change putting a micro switch under it so you can turn the power off?
Offline Fraser
« Reply #152 on: April 27, 2017, 06:40:33 pm »
Regarding the 'off' current. Have you checked the current draw after the camera has been off for a while ? It is not uncommon for modern thermal cameras to have three power states..... ON, Standby 1 and Standby 2.
ON is obvious, Standby 1 is a sort of warm Standby where the camera can restart very quickly as the computer is still booted. standby 2 is a cold standby where the computer is effectively off and needs to boot from cold when the camera is instructed to power ON. The FLIR E4 and several other cameras I own have this two standby state design. Cold standby should have a current draw measured in micro amps.
The camera drops into Standby 2 after a Standby 1 timer times out. The timeout period is different with each brand of camera.
Fraser
« Last Edit: April 27, 2017, 06:46:54 pm by Fraser »
Offline Kilrah
« Reply #153 on: April 27, 2017, 06:52:48 pm »
Nope, but will try. I have little hope though since it starts drawing those 7mA as soon as power is connected, before the first power on.
Offline chili_red
« Reply #154 on: April 27, 2017, 07:12:11 pm »
A couple questions,
What is the brand of that power supply you are using?
And
What memory card do you have in there?, it looks orange in the picture and was wondering if that's a eyeFi card.  If it is can you check the voltage draw after removing it.
Offline TheSteveTopic starter
  • Living the Dream
« Reply #155 on: April 27, 2017, 07:37:56 pm »
I doubt the "off" current drain goes any lower. I left the battery in my camera which was switched for a week and the battery was fully drained. I know the manual recommends storing the camera with the battery removed, and now we know why.
VE7FM
Offline HighVoltage
« Reply #156 on: April 27, 2017, 07:43:10 pm »
Thanks for the tear down picture.
I still have to fix my trigger switch that is stuck and and it seems to be easily removed.
Offline Kilrah
« Reply #157 on: April 27, 2017, 08:06:29 pm »
Yup it's an old eye-fi card, only full-size SD I found in my drawers  :P
Drain doesn't change without, unsurprising since there's no reason it would be powered when the whole camera is off.
Fraser TheSteve posted a bunch of teardown pics near the top of the thread.
The regulator is an RD DPS3005 in a 3D printed case I designed. Really neat little things.
I'll now be trying to print this during the night:
I printed a stub and it seems to fit reasonably well:
« Last Edit: April 28, 2017, 06:31:57 am by Kilrah »
Offline chili_red
« Reply #158 on: April 27, 2017, 08:20:05 pm »
Thanks for the info Kilrah, figured the eyeFi card wouldn't draw but you never know, have a couple of them laying around myself.
Any chance you could upload the .stl file for the battery case, I have a 3d printer also and would like to print one out also.
Thanks
Steve
Offline Kilrah
« Reply #159 on: April 27, 2017, 08:27:02 pm »
I will of course post it as soon as I've verified it works :) Already made 2 changes...
Pisses me off when half the things I download and print end up in the trash becasue they're lousy designs, so I try to do a bit better*...
*results not guaranteed
« Last Edit: April 27, 2017, 09:27:17 pm by Kilrah »
The following users thanked this post: chili_red
Offline Kilrah
« Reply #160 on: April 27, 2017, 08:31:24 pm »
The original gasket may be recoverable ? If you soak it in hot water it will usually return to shape. Then superglue the ends together if it has broken. I always use Loctite Power Flex flexible superglue as it is perfect for such flexible items and uses a rubber filler in its mix.
Looks like I've chucked it already...  :--
I think I will try to fill the groove flush with silicone. Or jsut leave it like this, the "counterpart" pushes in close to 1mm already so should make quite a bit of a seal on its own at least for dust.
« Last Edit: April 27, 2017, 08:33:13 pm by Kilrah »
Offline Fraser
« Reply #161 on: April 27, 2017, 10:43:29 pm »
Just to correct a comment made here. I was not the chap who posted pictures of the cameras interior. I have not had a chance to do anything with my camera yet. The battery is en route to me from overseas and should arrive any day now.
Nice work on the 3D battery casing.
Fraser
Offline mrrrwhat
  • Country: hk
« Reply #162 on: April 28, 2017, 01:34:52 am »
Do the eyeFi card wifi function work on this camera or not?
Offline Kilrah
« Reply #163 on: April 28, 2017, 06:35:56 am »
Might not because the camera doesn't put things in a DCIM folder like a common digital camera but in an IMG folder. Anyway the card is out of support so the WiFi functions are as good as dead as it can't be reconfigured anymore (yay for server-based stuff...) so I can't check.
The case print failed, started it again...
@Fraser I've corrected, had confused indeed
« Last Edit: April 28, 2017, 06:42:43 am by Kilrah »
  • Living the Dream
« Reply #164 on: April 28, 2017, 06:55:36 am »
If the battery case turns out I'll probably print one for fun. Have you checked to see if the camera will charge the battery for you? I would think it would need all 4 contacts for that with the sense resistor and the thermistor.
VE7FM
Offline nfmax
« Reply #165 on: April 28, 2017, 06:57:59 am »
I found this issue as well. A fully charged battery was down to two bars in three days or so. I thought my £55 battery might have been a lemon but it looks like it's the unit itself.
That means the battery holder gasket is going to take some wear, unless you leave it permanently charging
Offline Kilrah
« Reply #166 on: April 28, 2017, 07:12:39 am »
Gah, it indeed doesn't. Can someone measure the middle contacts at normal temp? Probably jsut a matter of putting a resistor between them.
  • Living the Dream
« Reply #167 on: April 28, 2017, 07:30:10 am »
Already done on page 1.
Here is the info again:
The "S" sense pin appears to be tied to the positive output through a 7.7 K resistor.
The "T" temperature pin is connected to negative through a NTC thermistor which has 11.5K at around 20 degrees C.
« Last Edit: April 28, 2017, 07:38:27 am by TheSteve »
VE7FM
Offline Kilrah
« Reply #168 on: April 28, 2017, 07:50:15 am »
Woops sorry for that.
Installed 6k8 and 10k resistors on the respective sides and we have charge :)
Funny, there was a thread about wire-wrap the other day, guess I've jsut used that again after maybe 15 years or so  :-DD
Offline HighVoltage
« Reply #169 on: April 28, 2017, 09:36:35 am »
OK, I fixed the sticky trigger knob.
Both sides of the knob had some left over plastic attached.
The switch itself was alright.
Now it works perfectly.
Offline Kilrah
« Reply #170 on: April 28, 2017, 09:50:56 am »
Mine is a bit creaky as well, guess I'll check it while I'm there.
Re the case: the 2 18650 just fit (BMS will have to go on top, too short), the case fits in the camera well... but I didn't notice the end cap had a V notch at the center, so a redesign is needed :(
Offline Fraser
« Reply #171 on: April 28, 2017, 12:34:44 pm »
Making a battery pack is often challenging as the OEM batteries often have very thin plastic cases that are not easily reproduced using a 3D printer. I have seen some that are wafer thin but use very robust plastic to counter this. One technique I have used is 3D printed end caps and thin modelers ABS plasti-card for the rest of the case. The plasti-card is very thin but tough. It also bonds easily to 3D printed ABS parts that my printer produces. I use plastic weld to melt the parts together. If you are short on length, you could use thin ABS plasti-card at the ends of the battery.
http://www.newmodellersshop.co.uk/plasticard.htm
Fraser
« Last Edit: April 28, 2017, 05:25:06 pm by Fraser »
Offline Kilrah
« Reply #172 on: April 28, 2017, 02:57:44 pm »
No need, the 1mm wall has printed surprisingly well. It's a bit fragile but once everything's sorted I'll make a cap that can be glued on and will add the rigidity.
New version printing...
Offline Kilrah
« Reply #173 on: April 28, 2017, 06:32:10 pm »
OK, revised design fits. I'll make it 1mm longer becasue there's still a little margin and post the file, then work on the cover. That will be 1.5mm thick I think.
Offline onesixright
« Reply #174 on: April 28, 2017, 06:41:52 pm »
@kilrah what software your using?
