Got my charger today and ended up spending a couple hours with the camera. Battery life is quite good, maybe 3h or so in total running and a chunk of it with max display brightness and I'm down one bar on the indicator. Also, the 1.30 firmware adds the palate I was thinking of, it's called "Iron" though there was a "Hot Iron" variant that was even on the old firmware.
Only time I notice the sensor noise is really low dynamic range where it tends to be warmer, but there's occasionally a sort of crosshatch pattern in that situation, otherwise the fidelity has been great, hard to believe the sensor is only 160x120. I'm getting a hang of figuring out when things are reflections or what effects are the result of the sun or other things too, it's a new world to get used to seeing in some respects.
I hooked up the RCA output to a cheap capture card ($6 or so) and got video on the PC with no issues, the screen goes off when it's sending video, but the video is an exact copy of what's normally on the display. It may be my imagination, but the framerate almost looks higher on the video connection - if it is, it's not by much, but it seemed smoother than I'd expect from 9fps. My unit had a broken strap tab (making it a good chunk cheaper!), but I got a small piece of rope around the base and through the tab on the other side and it works just fine.
For some reason, my readings seem to be a little high - 3C or so at body temperature and a bit more at the high end of the range. I think this is probably due to my settings, I'm running all defaults and while the ambient temp and humidity are about right, I'm not sure everything is set properly, will have to look into it, the emissivity settings were correct at least for the skin tests, and the relative differences seem to be right, best I can tell. One notable exception to running hot is foliage - it seems to read very cold most of the time. Probably partly because of the water transfer out the bottom of leaves (this was in the evening) and partly because of the material itself, but it was interesting to see negative number readings on a warm day outside.
