Author Topic: Radioactive thermal imager?  (Read 3394 times)
Online mikeselectricstuffTopic starter
    • Mike's Electric Stuff
« on: February 04, 2017, 07:25:45 pm »
This EEV P4428 has "radioactive material" stickers on the camera and case - can't see any reason why a TIC would use anything radioactive.
Maybe it got contaminated, or someone just wanted to reduce risk of it getting stolen..?
It does look like it's just tape stuck on rather than original labels.
http://www.ebay.co.uk/itm/EEV-P-4428-Thermal-Imaging-Infrared-Camera-/201801715045?hash=item2efc51cd65:g:DDIAAOSw2xRYkHyU
Day Job: Mostly LEDs
Offline Bill W
    • Fire TICS
Re: Radioactive thermal imager?
« Reply #1 on: February 04, 2017, 07:36:30 pm »
The tale behind this is that early TIC lenses had Thorium in the anti-refelction coatings, and so were mild alpha emitters.
This one, and indeed all P4428 DO NOT have Thorium coatings but once the Navy had got the idea that 'thermal cameras might be radioactive' (the older P4228 were, as were the bigger lenses in the P4430) they just put stickers on regardless !
The tube faceplates also had Thorium coatings for a bit longer, it was even said   :-DD that this helped balance the helium loss from the 'soft' tubes.
regards
Bill
The following users thanked this post: joe-c, Neomys Sapiens
Offline joeqsmith
« Reply #2 on: October 16, 2017, 05:24:23 pm »
I have an old camera that uses thorium fluoride for the optics.  They warn you about handling them.
I'm always curious with the people who buy used mass spec and optical equipment like this, how do you know what materials it has in it or worse, in the case of a mass spec, what it was used for.
Offline joeqsmith
« Reply #3 on: October 17, 2017, 03:40:57 am »
I think they have to have warnings on them now and I believe they changed the percentage that could be used.
Offline Ultrapurple
  • Just zis guy, you know?
    • Therm-App Users on Flickr
« Reply #4 on: October 17, 2017, 08:35:00 am »
I know nothing about thorium fluoride - what is its spectral range? Any chance of a picture of the relevant bits and pieces and some info on the camera?
Rubber bands bridge the gap between WD40 and duct tape.
Offline joeqsmith
« Reply #6 on: October 18, 2017, 02:50:28 am »
Here's the camera in operation
https://youtu.be/JlY4v3ruT3g
Offline Bill W
    • Fire TICS
« Reply #7 on: October 20, 2017, 11:20:37 am »
Thoruim Fluoride is used as an anti-reflection coating, not a bulk optical material.
May date the camera back to 1980's at a guess.
regards
Bill
