Hello everyone!
From what I understand, reflected temperature correction is the correction that you need to input in a thermal imaging device in order to remove the background radiation. I've noticed that Fluke has a setting for reflected temperature correction and most people suggest using an aluminum foil has a corrector since it has a considerable low emissivity.
However, I don’t have the Fluke camera but rather the Thermal Expert Q1 and I can’t find any reflected temperature setting when I go through the TE settings. Does anybody know why that's the case? Does TE just simply automatically correct background radiation?
Thank you so much!
