Hi all,
I'm currently looking into using thermal imaging in some biology research and am trying to work out the best low end/budget product that will give the highest accuracy in temperature readings. We plan to use the thermal imager to measure the temperature of various microhabitat surfaces as well as body surface temperatures of reptiles. I would expect the temperatures we're measuring would mostly fall somewhere between 5 - 60 degrees C.
We had initially looked at the FLIR One cameras as the hybrid thermal/visual output looks like it would make it quite easy to see exactly what features we're looking at (and measuring) without needing to spend extra for a higher resolution sensor. However, with a reported error of +/- 3 degrees C this would probably not be accurate enough.
Unfortunately, I don't yet know how much funding we'll be able to secure but at the moment I can't see anything over $1000 being a realistic option.
So I have two main questions I'm hoping someone might be able to help me with:
a) Are there any similar(ish) low-end products which actually have a lower temperature measurement error than the FLIR One?
b) Has anyone here measured the accuracy of any of these products themselves, and have any tips or tricks on how to reduce measurement error and get the most out of these cheaper imagers?
Cheers,
SB
