Why would someone share their certificate? What is the point of signing binaries then, if anyone can sign anything using your certificate? Sign it with your own certificate or disable signing.
Good point, but then why did he distribute his source code, which requires signing? I finally did figure out a way around this though. I simply went into the project's properties, and told it not to sign the compiled EXE file. So now at least I can compile it.
Now I'm running into a new problem though, and that is that the initialization command which the software tries to send to the Seek camera, doesn't work for Seek Compact Pro (I assume it worked for the standard Seek Compact, but I don't have one to test it on).
Has anybody yet done a USB signal dump on the initialization "conversation" that the official Seek Android app actually has with the Seek Compact Pro camera? Hope somebody dumps this at some point, because I'm guessing it's completely different for the Compact Pro than for the standard Compact.
