If you've got time to kill, superb results can be obtained by combining the techniques if your subject is suitable (ie, still):
- video the scene, panning in a zigzag fashion, apply superresolution, panorama process
- using a tripod, take a series of 10-sec videos, methodically moving the camera in a pan-and-scan between runs, then use RegiStax or similar to create individual de-noised images which can then be panorama processed
- as above but jiggle the tripod a bit to simulate hand shake so you can run superresolution before stacking and pano processing
All good, clean, time-consuming fun!
Sometimes you just have to trust to luck, though. Like when you only have access to a place for a limited time and you just have to
hope you've captured everything you need, in good enough quality to work with later. An example is the image below (click to embiggen) of Abu Simbel in Egypt.
Abu Simbel (Egypt) thermal panorama
I didn't expect to be let into Egypt with a thermal camera, let alone be unmolested when I started waving it around. In fact, the only place there was the remotest problem was atop the Aswan Dam, where the armed guards wanted to assure themselves I wasn't taking video, which is banned. (Stills are fine, but I didn't want to have to explain myself to them...)
