Thanks for the input. You all help me troubleshoot the case
What do you mean with "burn in" and FCC?
I've seen stats in this forum with changing temperature readings over time (graphs). Is that what you are referring to with burn in?
I would have hoped the behavior would be that the temperature initially changes fast but slows down after some minutes (and maybe stabilizes completely at some point, although by that point the battery of the phone probably ran out already). Here it doesn't seem to be the case, see for example the switch off switch on of the point measurement. after that action the temperature reading jumped more than 1 degree.
I am trying to understand whether it is a software (app) issue or the camera itself. The sudden jump after switching off switching on seems to suggest software, but who knows.
Note that times I logged are minutes:seconds. I don't think the chair changed much in temperature within the total measurement time of 11 mins.
