We produce an automotive board assembly, to which a connector, with significant thermal mass, is soldered to after all the other components are in place.
This is an electronic throttle control, and thus considered a safety assembly.
This is quite a large volume assembly, 500K/year, and it is processed via a robotic soldering machine with a single preheating stage.
The solder is SAC305. Thus a camera with a +350C rating should be sufficient.
Whoever chose the robot before my time here, did not take into account the quite different thermal masses on each soldered joint. The result is uneven solder joints. Bad news for for a safety related assembly. We have played around with temperatures and solder tip times, but are essentially just guessing,
We have tweaked and tweaked the profiles, but cannot get reliable joints all the time.
Rather than keep guessing at possible solutions (which could include another robot with a different profile from the first one), my thinking is that an IR camera would help me visualize my problem.
The board itself is about 4cm by 7 cm.
Does my idea make sense? Any camera suggestions?
