Author Topic: Thermal Camera teardown - Raytheon Cadillac DeVille Thermal Nightvision camera  (Read 21347 times)
Online FraserTopic starter
I dug my two Raytheon Cadillac DeVille cameras out of the 'awaiting repair' pile today.
Both cameras need a new chopper wheel as detailed in a previous post on these thermal cameras. The membrane of the chopper wheel can split over time in these cameras due to the constant heat to which they are exposed. This was also an opportunity to inspect the PCB's for any potential issues. IT is just s well I did as there was an issue with both. The problem took the form of tantalum capacitors that are splitting ! They have not burned-up as is their usual form of 'suicide' but cracked cases cannot be good so they are going to be replaced. Only one value shows this issue on both cameras, 330uf @10V rated. Both cameras were built in late 2000. I have marked the cracked capacitors with a blue marker to identify them but I will replace all the 330uF Tantalums as a precaution. There are quite a few used in these cameras.
By way of introduction to these cameras, they are designed and built by Raytheon for Cadillac and based on the Raytheon Thermal Eye 300A. The sensor is a Peltier temperature stabilised BST FPA. A chopper wheel is required for this sensor and is the standard Thermal Eye part. All electronic components are located on a single PCB with the rear of the case acting as a heatsink for the Peltier element. The lens is mounted in the plastic front section of the case and comprises a large diameter Germanium element combined with some form of plastic lens at the rear. An unusual lens design likely to be due to BoM cost restrictions for the camera. The fragile Germanium lens is protected from stones and dirt by a Germanium window that may be changed by the owner if it is damaged. In an automotive deployment, such a lens protector is essential if no other form of lens impact protection is employed. The Germanium window is heated in very cold weather by a built in heating element ring and thermostatically controlled.
The important specs now, the camera has a 320 x 240 pixel BST array and the output is 60fps making it suitable for use on a fast moving platform. The BST camera does not need the FFC flag and event found on many microbolometer cameras so there is no frozen frame distraction for the driver. The BST FPA was and still is an excellent choice for automotive deployments. As a 60fps 320 x 240 pixel thermal camera made by Raytheon, these are liable to ITAR regulations if being shipped between countries.
EDIT - Correction on import/export rues by Bill W who knows a lot about such......
"A slight correction on export controls, these are not ITAR but are Wassenaar dual use controlled so need a license to cross borders, apart from internally within the EU."
Hope you enjoy the pictures.
Fraser
« Last Edit: August 09, 2016, 04:42:32 pm by Fraser »
Inside the rear case
More
More
Failed 330uF 10V tantalum capacitors. Marked with blue marker pen.
The following users thanked this post: MapleCoast
The Patent detailing the design of this camera is attached.
The automotive deployment Patent US5763882 of 1998 is a duplicate in many areas but describes a 'low cost night vision camera'
http://www.google.co.uk/patents/US5763882
It should be noted that the term 'low cost' was relative to the industrial thermal cameras of that era costing more the $40K. These cameras were not a cheap option from Cadillac, that is for sure.
The Cadillac DeVille cameras are still popular and to be found on ebay. They range in price depending upon condition but expect to pay between $150 and $500. Their popularity stems from their rugged construction and ease with which they may be deployed on a vehicle for navigation in the dark and hunting. You just feed the camera with 12V DC and it produces NTSC composite video. No adjustments or commands, it is fully automatic and simplicity itself. People on You Tube have shown these being used in Pan Tilt Lamp housings an bolted behind the grille of their cars. They cost less than the Audi and BMW Autoliv FLIR cameras and, unlike those nightmarish units, the Raytheon is easy to deploy without any hacking needed.
Note that many of the cameras on the market are circa 2000/2001, will have broken lens protectors and split chopper wheel membranes. As such these should be dismantled, cleaned and serviced if you want the best out of them. Many You Tube videos using these cameras show signs of a poorly camera in need of some TLC.
As a point of interest, these Raytheon BST sensors and electronics design are used in EEV(E2V) ARGUS 2 and ISG Talisman firefighting thermal cameras.
Fraser
« Last Edit: August 09, 2016, 04:39:17 pm by Fraser »
Interesting Kemet Tantalum failure analysis document. It even shows a thermal camera being used to detect failed Tantalums.
Fraser
Offline nidlaX
Nice teardown and info Fraser!
Do these sensor modules have any type of temperature read-back capability built in?
NidlaX
No sadly the BST sensor array in this camera is non radiometric and does not easily provide precise temperature output for radiometric tasks. There have been clever designs using  the BST sensor that enable it to be used in radiometric applications, but for such tasks the microbolometer is a better choice.
Fraser
Offline Bill W
    • Fire TICS
The temperature measuring options on fire cameras that used the Raytheon BST (EEV Argus2, Marconi Argus3, ISG Talisman/K90) all used Raytek spot temperature sensors aligned with the camera view.
The BST is a 'ferroelectric/pyroelectric' detector so responds to changes in energy, hence the chopper, so is unsuited to measuring temperature by itself.  The only way is if the chopper is both solid and its' temperature is known when it becomes a bolometer that shutters at video rate.  The standard chopper is translucent and acts as an unsharp mask filter, which gives the BST image its' classic dark halo effect.
http://www.fire-tics.co.uk/images/A2R_TI.jpg
Bill
www.fire-tics.co.uk
Removing the chopper wheel from a Raytheon Thermal Eye camera .......
The Chopper wheel is a pretty fragile assembly that is attached to its drive motor using a press-fit. That is to say, no screw or adhesive is used.
The frame of the chopper wheel would break if any attempt was made to use it in the removal process. The removal requires care and an understanding of the 'hard points' on the wheel. There is only one hard point on the chopper wheel, the central boss.
If the membrane is totally destroyed and of no use, it would be feasible to use the standard knob removal technique where a strong nylon cord is threaded under the hard point and used to pull the assembly off axially. There IS a risk of breaking the central boss however. I opted for the leverage approach as that is safer and preserved the membrane for the purposes of templating a new one.
There must be no levering on the fragile frame, only the central boss. In order to achieve this I borrowed a serrated edge bread knife from the kitchen. This has a strong but thin blade and the serration permits force either side of the motor shaft rather than just on one side. To assist in the process of removal I heated the boss with a hair dryer for around 15 seconds on high heat. The knife is then twisted carefully to prise the boss off of the shaft. On my cameras the boss popped off easily. Take care and take your time. Rotate the boss 90 or 180 degrees if it is being stubborn and this will work it off of the shaft.
When the chopper wheel is off of the shaft you can see a reflective indexing disk on the rear. this works with an IR reflection sensor on the motor deck to provide chopper wheel position sensing for the synchronous chopper spiral timing circuits. It is very important that this index is correctly positioned with respect to the spiral start point.
Fraser
The chopper wheel mask is made up of translucent dots so is hard to photograph. I found a blue background helped so i have taken some pictures that i hope will help others to make their own replacement spiral chopper shape for use with the original wheel frame. Opaque spriral's will work for most peoples applications of these cameras.
There is another chopper wheel in one of the pictures. It is from an EEV Argus 2 camera. I have yet to establish the compatibility of this slightly different chopper wheel with the Cadillac camera.
Fraser
« Last Edit: August 09, 2016, 04:26:47 pm by Fraser »
Higher resolution chopper wheel image
Raytheon Cadillac camera Chipset
Altera FLEX EPF10K100EFC256-3    10K series FPGA
ISI 61LV6416   64K x 16 SRAM 3V3
AMD L400BB55RI   256K x 16 Boot sector Flash Memory
ADV7127    240 MHz 10 Bit High Speed DAC
Analogue Devices M 01   Tiny RS232 Transceiver
NAT Semi 01AB CLC5602IM  Dual high output video amplifier
TI HB244 98K EELD    Tri-State Octal buffer
OP279 G 943 G3332  Dual high output current Op-Amp
LT 945 112913     Low dropout regulator 1V3
4412   Mosfet
AD9220 ARS 9931 AP6958.1   12 Bit ADC
Altera EPC2 TI32 Cad489949   Altera 10K configuration Flash RAM
H 1135IB    360Mhz video Op-Amp
NAT Semi JM86AB LMC6084IM   Precision CMOS quad Op-Amp
Zetex T6790   Diode array
OP279 G009 G8986     Dual high output current Op-Amp
NAT Semi 02AB LMC 6082IM  Precision CMOS dual Op-Amp
LT  012 1624I    Switching Regulator controller
LT 002 111825     Low dropout regulator 2V5
Raytheon 2270-35  BST 320 x 240 Pixel Array
« Last Edit: August 09, 2016, 06:12:39 pm by Fraser »
Very nice Fraser. From your linked paper it looks like those caps were cracked by improper storage before soldering which started the cracking.
Offline AKMac
For someone also attempting a repair on one of these cameras, with I'm guessing a burnt voltage regulator and several failed capacitors, how do you determine information about these tantalum capacitors? I notice that the 330uF caps say 337 on top; are those numbers related?
AKMac,
Just Google "Tantalum capacitor markings" and all will be explained. There is a voltage rating as well  ;)
http://www.radio-electronics.com/info/data/capacitor/capacitor-markings.php?sa=X&sqi=2&ved=0ahUKEwjjm5381aPZAhUnBsAKHUPPBoUQ9QEIDjAA
« Last Edit: February 13, 2018, 07:57:01 pm by Fraser »
Offline Bill W
    • Fire TICS
A common failure mode is that of tantalum capacitors used  on power input or SMPS smoothing being hit with surge current.  That is more a total burn out than the cracks Fraser shows.  The Raytheon BST Core used standard tants (for example AVX TAJ series etc) in a few places where it would have been better to have used surge rated (for example AVX TPS).
From Frasers' pictures it looks like a one size fits all design approach with the biggest Tant they could find (330uF).
The 200 / 205D core for OEM use had 220uF for the actual sensor biases etc, and I don't recall any 330uF on the SECCA (processing PCB) either.  It was the SECCA ones that burnt up.
The Cadiallac PCB looks like both those OEM PCB combined, but without some of the OEM interfaces.
Bill
Offline Bill W
    • Fire TICS
Had a check, and the 'newer' SECCA from the 205D OEM core has one or more 330uF/10V/0.2 ESR on all the switch mode supply voltages - of which there are quite a few.
That dated from 2003.
The older '200' series from 1996 to 2002 used 220uF's and a lot less voltage rails pretty much all on 5V.
Bill
Offline bostwickenator
Necroing this topic since it's the best source of information about this camera I can find on the internet. Also backlinking to Fraser's previous topic: https://www.eevblog.com/forum/thermal-imaging/thermal-camera-affordable-raytheon-night-vision-thermal-camera-unit/
@Bill how does one go about figuring out this is controlled by Wassenaar over ITAR? Is it a matter of criteria or is some master list of device models kept?
Offline Bill W
    • Fire TICS
There are lists of criteria over what is under Military item controls (US=ITAR) what is under dual use item controls (US=EAR)
All the dual-use regulations have simply lifted the text from Wassenaar and dropped it into their national documents (US=EAR, EU27= regulation 428/2009).
For the US there has often been a turf war between Dept of Commerce (who run EAR, and get moaned at by manufacturers) and Dept of State (who run ITAR and get moaned at by the military fearing assault aided by dual use items).
As the UK has a single document for both MIl and Dual-Use lists, the UK explanation is quite helpful:
https://www.gov.uk/government/publications/uk-strategic-export-control-lists-the-consolidated-list-of-strategic-military-and-dual-use-items-that-require-export-authorisation
A key point is that while the lists say WHAT is controlled, they do not say much what the restriction then should be.  Each license application can be treated individually (especially by the US) and restricted accordingly.
So by example with BST cores:
EEV/Marconi got BST cores in crates of 24 on a 'any of these countries/user types' and  'tell us where they went at the end of the month' basis.  We were a UK approved big corporate military supplier with all the compliance that goes with it.
ISG only got BST cores one at a time after each core had a pre-approved end user.  They were a small private company.
Bill
The following users thanked this post: bostwickenator
Bill that is an amazing answer thanks for taking the time to write that up for me.
From my read of the document you linked this camera falls under 6A002.a.3.g but isn't excluded from regulation because it fails "Incorporates an active mechanism that forces the camera not to function when it is removed from the vehicle for which it was intended;"
Offline Bill W
    • Fire TICS
Thanks.  Not sure your para number is right, although the wording is.  6A002 applies to sensors, (6A002.a.3.f being thermal camera ones) while cameras 'using sensors of 6A002' come under 6A003.
The restricted features (and exemption clauses) for thermal cameras are 6A003.b.4.b and following notes
The clauses in Note 3.c cover vehicles, added specifically for Cadillac/BMW etc to be able to export cars or for owners to drive internationally.  Probably illegal to drive a TIC fitted car to Belarus though.
The US EAR document is here:
https://www.bis.doc.gov/index.php/component/docman/?task=doc_download&gid=2338 but is a lot harder to read
It does however include more on US control policy, one of which allows medium performance finished cameras (eg 60Hz 320x240) out to friendly places, but not cores for those friendly places to build their own cameras !
FLIR must have written it......  ???
Bill
You are right I was off my one!
6A002.a.3.f. Non-“space-qualified” non-linear (2-
dimensional) infrared “focal plane arrays” based
on ‘microbolometer’ material having individual
elements with an unfiltered response in the
wavelength range equal to or exceeding 8,000 nm
but not exceeding 14,000 nm;
I wonder if the text I quoted about an interlock was added after Cadillac stopped shipping these cameras. From the descriptions of the Volvo/BMW thermal units they use a software interlock.
My unit arrived today a little bit of wire loom bodging was enough to get me some sample footage. A few notes about this unit.
  • They did not skimp on the amount of glass fiber in the plastic of the casing. I handled the unit for all of 3 minutes total and my hands are still itching hours later.
  • The chopper wheel is kinda loud, it sounds like an off balance CD. Turning the camera around even at moderate angular velocity causes clattering noises from the disk :/.
  • The field of view is pretty tight it seems well designed for it's purpose in that regard.
  • At startup the camera draws 4 amps for a second or so.
  • The SNR is a little disappointing. I don't think this compares favourably to my Seek Thermal Compact Pro in this regard. I'll do side by side tests
I'm wondering if the chopper wheel is damaged or somewhat opaque due to age. It feels like the camera should perform a bit better than this. I'll pop it open and see soon.
Test video
