Author Topic: Thermal Imaging Gallery  (Read 116067 times)
Offline frenkyTopic starter
  • Country: si
    • Frenki.net
Re: Thermal Imaging Gallery
« Reply #50 on: November 23, 2016, 01:57:01 pm »
Camera: ThermalExpert Q1
Lens: 13mm f/1.0
NiMh charger:
Steel fireplace:
Offline romanv
« Reply #51 on: December 06, 2016, 07:03:50 pm »
Using an E4 for tire / suspension analasys at track days.
  • Country: si
    • Frenki.net
« Reply #52 on: December 28, 2016, 07:59:14 pm »
Lens: 13mm f/1.0
Too bad leds are almost completely cold...
Offline paradigmic
« Reply #53 on: January 08, 2017, 08:39:06 pm »
Camera: DRS E6000
Lens: 62mm f/1.1
Cap bomb with 16 caps worth of powder in it. This camera is 30hz so each of these frames are 1/30s apart.
  • Country: si
    • Frenki.net
« Reply #54 on: January 08, 2017, 10:46:45 pm »
@paradigmic: Nice!  :-+
Lens: 13mm f/1.0
I've really got to put some rubber/foam seal around this window...
  • Country: si
    • Frenki.net
« Reply #55 on: January 16, 2017, 11:22:21 pm »
Lens: 13mm f/1.0
Subject: Pizza wannabe  ;D
Offline encryptededdy
« Reply #56 on: January 18, 2017, 05:51:40 am »
Camera: Therm-App (Original)
Lens: 19mm f/1.1
Subject: Microsoft Surface Book (running CPU stress test)
Offline tomas123
« Reply #57 on: January 20, 2017, 01:48:00 pm »
I see, that our Therm-App to Flir-Tools workflow works fine ;-)
Offline Bruno28
« Reply #58 on: January 27, 2017, 11:55:26 am »
My first thermal camera
Camera: Therm-app TH
Lens: 6.8mm lens.
https://youtu.be/G7VPPYR09hw
Gas stove
Veins in arm
MacBook pro
Garage wall
Flashlight
Bat flying at night
Fridge
Milk (you can see how full it is)
Car
Sent from my SM-G935F using Tapatalk
« Reply #59 on: January 30, 2017, 01:23:33 am »
Upscaling test using the "Waifu2x" upscaler (http://waifu2x.udp.jp/). I'm very impressed with the results.
« Last Edit: January 30, 2017, 08:26:14 am by encryptededdy »
The following users thanked this post: Pinkus, joe-c, DaneLaw, MyThermalWorld
  • Country: si
    • Frenki.net
« Reply #60 on: January 30, 2017, 09:30:10 pm »
That is really cool upscale algorithm.  :-+
Offline Pinkus
« Reply #61 on: January 31, 2017, 07:58:48 pm »
Nice find! Thank you
Offline rjardina
« Reply #62 on: February 01, 2017, 12:53:24 pm »
Had a customer a while back stating the unit was blowing fuses in the disconnect.
initially I didn't even take a thermal image. Due to the condition of L3 fuse just by
looking at it with the naked eye. I told them to call an electrician. An electrician
came out and stated it wasn't the disconnect. The company I was working for didn't
always send back the same tech. After other techs replaced the motor and heating
elements costing the customer well over $4,000 USD. That was just for the work
my company did. The customer stated they were replacing the fuses twice a day at
$10 a piece. About six months later I get a call out there, the issue was never fixed.
Told the customer the same thing. Customer was pissed, and arranged for me to
met the electrician. I met them there one master and one apprentice electrician.
Spent two or three minutes trying to explain the issue with the electrician, with no
luck. Got the thermal camera out. The Apprentice said, "We got to get one of
those". The Master turned to him and said "Callate!". Which is "Shut up" in
Spanish. Then we all agreed what the issue was. After the disconnect was
replaced the customer didn't have any other issues.
Offline Platonas
  • Country: cy
« Reply #63 on: February 03, 2017, 03:59:56 pm »
On the 30th of January I received my brand new FlirE4 v2.11.
It is still unmodified and I will do the mods in the upcoming days.
The picture below shows the two compressors of an air-drier system.  The right one (hotter) had a fault that kept it always on.
Offline Platonas
  • Country: cy
« Reply #64 on: February 06, 2017, 10:46:05 am »
After successfully upgrading my Flir E4 to the E4+ I captured my self on duty.
The pictures are of a DC fuse loaded to 270A.
Resolution (thermal) 320x240.
Offline tkuhmone
« Reply #65 on: February 06, 2017, 11:03:02 am »
Are those fuses used on telecomm systems 48V DC supply ? I remember seen similar fuses at company telecomm lab (with many 250A rectifiers installed)
Timo, OH7HMS
Offline Platonas
  • Country: cy
« Reply #66 on: February 06, 2017, 08:15:49 pm »
Yes tkuhmone, they are on a telecom system of 48V DC.  I was testing the batteries in discharge mode (by turning off the rectifiers) and noticed the fuse was a little bit hot.
Offline jetdail
« Reply #67 on: February 06, 2017, 09:55:08 pm »
seek compact pro +moto z+usbc adaptor
« Last Edit: February 06, 2017, 10:26:08 pm by jetdail »
Offline electr_peter
  • Country: lt
« Reply #68 on: February 07, 2017, 09:38:04 pm »
In the second picture I see gas stove, but temperature reading in the centre is strange. Is that a bug in SW?
Offline jetdail
« Reply #69 on: February 07, 2017, 10:19:59 pm »
pretty hot , i ve got a good gas  stove , don t you think ????  yep , a good sw bug, and not only this one  ...waiting for a good application for this camera , maybe one day Seek technicians will go to work , when you go to they site and see the crappy forum and only old posts, you know it won't be tomorrow  ....
Offline Bruno28
« Reply #70 on: February 08, 2017, 02:18:15 am »
Lens: 6.8mm lens
Boiling water
Cooking pasta
Oven
Fridge
MacBook Power supply
Flashlight - Nitecore tm26gt
The following users thanked this post: PointyOintment
Offline in.Vitro
« Reply #71 on: February 08, 2017, 04:36:11 pm »
Can you post some Black and White Pictures? =)
  • Country: lt
« Reply #72 on: February 08, 2017, 06:22:30 pm »
Temperature at the centre of the stove is shown as 2147483647 C (exactly 2^31 - 1) or ~2 Giga Celsius (GC). Last time I checked, gas stoves are not known to produce temperatures higher than the Sun and vaporise objects nearby, so software error is likely.
Offline Bruno28
« Reply #73 on: February 09, 2017, 09:39:49 am »
Here you go. Nothing amazing as they were taken to compare the standard app to the ThermAppPlus. All house photos or street view.
Offline bowhunter-57
« Reply #74 on: February 09, 2017, 08:51:29 pm »
Bruno those last few pics are very grainy why is that?
