Author Topic: Thermal Imaging Gallery  (Read 115848 times)
Offline bozidarms
  • Country: at
Re: Thermal Imaging Gallery
« Reply #100 on: May 27, 2017, 08:20:40 pm »
some images from DT-9885, lens f=22mm
Regards
« Last Edit: May 27, 2017, 08:30:23 pm by bozidarms »
The following users thanked this post: nongken
Offline Terabyte2007
  • It is purpose that created us... That defines us..
« Reply #101 on: May 28, 2017, 11:44:10 am »
The side of a chest freezer. I did this one a couple years back but still pretty cool.
Eric Haney, MCSE, EE, DMC-D
Electronics Designer, Prototype Builder
Offline jpb
« Reply #102 on: May 29, 2017, 12:07:01 pm »
I put some images up under the Keysight U5855A thread but I probably should have put them here.
Puppy, puppy's thermal reflection looking back at him (in glass door), puppy drinking and then his thermal footprints left behind.
Offline Platonas
  • Country: cy
« Reply #103 on: June 09, 2017, 08:51:17 pm »
Camera: Flir E4+
Images upscaled to 640x320 with Photoshop.
1.  The image of my Laptop's DVD writer after a CD burning.
2.  Condensing Unit of a CCU (Close Control Unit) by Emerson.  I was impressed by the fact that the copper pipes look colder to the camera than the part of the pipe that was covered by a white sticker (label).  The emissivity of the sticker is higher than that of the copper.  (Two stickers in rectangular form.  One in the middle and one to the right part of the pipe)
3.  Condensing units of CCUs.
4.  A compressor's top part of a chiller.
Offline Ultrapurple
  • Just zis guy, you know?
    • Therm-App Users on Flickr
« Reply #104 on: August 14, 2017, 09:42:40 am »
A few of my holiday hi-res thermal snapshots made with a Therm-App imager, ThermApp Plus and Microsoft Image Composite Editor, often with cropping and light post-processing in Paint Shop Pro X.
More background information on where these images were made can be found at at
I'm pleased to note that Opgal are using some of my images (with permission) in their promotional material. I retain the copyright of these images, which must not be re-used without my consent.
« Last Edit: February 08, 2018, 12:57:16 pm by Ultrapurple »
Rubber bands bridge the gap between WD40 and duct tape.
The following users thanked this post: schmitt trigger
Offline Adamsmiffy
« Reply #105 on: August 14, 2017, 07:43:21 pm »
Seek compact pro iOS.
Not seen many images from the seek so I thought I'd add a couple  :-+
Offline Jeroen3
  • Embedded Engineer
    • jeroen3.nl
« Reply #106 on: August 14, 2017, 08:19:22 pm »
I'm regretting buying the FLIR One looking at this resolution.
Offline schmitt trigger
  • Country: mx
« Reply #107 on: August 14, 2017, 08:56:28 pm »
Rightly so, the images are stunning!
I no longer have access to an IR camera, but a few years ago in my previous company, we had one.
One *very hot* August day in South Texas, exactly at noon time, I saw two identical vehicles, but one was white and the other black.
They were parked at the company's parking lot so I ran for the camera.
Took several readings of the vehicle's painted surfaces (avoiding of course the engine bay), and the average white temp was like 49C, and the black one was about 88C.
Made me a believer that, if you live in place with hot summers, one should get light colored vehicles.
« Last Edit: August 14, 2017, 08:58:03 pm by schmitt trigger »
The following users thanked this post: Ultrapurple
Offline JanHenrik
« Reply #108 on: August 15, 2017, 06:05:08 am »
Camera: U5855A
Software: NEC Avio InfReC
Offline Ultrapurple
« Reply #109 on: August 15, 2017, 02:33:47 pm »
Software for image stacking (eg Registax, Autostakkert!) and compositing (eg Microsoft Image Composite Editor) means that you can get reasonable results with lower resolution imagers, as I'm sure others have mentioned elsewhere.
Here are some composite images I made with a Seek XR (206 x 156) before I re-homed it.
Apart from the well known issues with noise, sensitivity, linearity and limited actual resolution, the Seek XR performed reasonably well for the price.
« Last Edit: August 15, 2017, 06:25:40 pm by Ultrapurple »
The following users thanked this post: ThermallyFrigid
Offline marshallh
    • retroactive
« Reply #110 on: August 21, 2017, 11:00:09 pm »
Flir Compact A65
Verilog tips
BGA soldering intro
Offline Bruno28
« Reply #111 on: September 05, 2017, 02:20:41 am »
I put together a quick video of some footages I've taken with the Therm-App 19mm and Therm-App TH 6.8mm
Offline IwuzBornanerd
« Reply #112 on: September 28, 2017, 08:45:10 pm »
Image of the back side of Seek circuit board sensor area viewed at a distance of 2 inches.
Camera: Late model Seek "compact"
Lens: XR lens with focus restriction removed
I am not opposed to exercise, unless it is an exercise in futility.
Offline Jhun80
« Reply #113 on: September 29, 2017, 07:29:17 am »
Seek Thermal  Compact Pro
Hot meal!
« Last Edit: September 29, 2017, 09:14:50 am by Jhun80 »
Offline Jhun80
« Reply #114 on: October 02, 2017, 12:50:57 am »
A bubble wrap
Offline Ultrapurple
« Reply #115 on: October 05, 2017, 02:26:13 pm »
Here's an unusual one - a thermal sensor actually scanning. You'll probably have to click the image to see the animated GIF or a higher resolution version of the file on the Flickr site.
This is quite remarkable: I pointed a 25Hz Therm-App camera at the sensor of another Therm-App camera and I could actually see the scanning in progress!
The frame rate of the two cameras differs slightly, which is how come we can see this effect. What you're seeing is the sensor on top of the ROIC (read-out IC) becoming very slightly warmer as each row is read out. This is actually happening 25 times a second but because the two cameras are running at nearly the same frame rate we get a kind of 'stroboscopic' effect, very like the effect you used to see on TV screens being filmed.
There's a decent description of why a filmed TV screen appears to flicker (which works in the same way) here if you want to know more, and the short movie linked from that page shows exactly what's going on.
I found it utterly fascinating to see, and I've never heard of anything similar being filmed before. This is definitely not caused by any other artifact such as a lighting effect or anything physically moving, and when I swapped the cameras round I saw exactly the same effect - but with the motion going in the opposite direction.
« Last Edit: October 05, 2017, 03:29:45 pm by Ultrapurple »
The following users thanked this post: daqq, Myself, 300EVIL, PointyOintment, nidlaX
Offline Ultrapurple
« Reply #116 on: October 24, 2017, 07:39:00 am »
Very high resolution stitched panorama of Gibraltar Airport and the Spanish town La Linea de la Concepcion.
This image is nearly 20 megapixels.
I had to fine-tune the jpg compression settings to make it fit the 1MB maximum file limit.
You'll need to download the image to explore it properly: it is well over 9,000 pixels wide. I think it's the most detailed thermal image I've ever made.
Imager: Therm-App Pro (uncooled LWIR 25Hz 640x480 <30mK)
Lens: 35mm f/1.1
Driver software: ThermViewer
Stitched by: Microsoft Image Composite Editor
Tweaked in: Paint Shop Pro
There are a couple of slightly iffy areas in this panorama due to issues with the stitching but overall I'm quite pleased with the result. I hope to be able to make even better-quality images in the future: this capture was done under a certain amount of time pressure and with a slightly flaky imaging setup.
There is a better-than-HD resolution video of the central portion of the image on Flickr.
Also on Flickr is a high resolution panorama of Gibraltar town and the harbour taken from a slightly different location.
The image below is a Barbary macaque (also known as a Barbary Ape, although it's actually a monkey), again made with the Therm-App Pro 35mm F/1.1 and ThermViewer, black hot. I was only a few feet from the animal and struggled with the relatively narrow DOF of the lens at that distance.
There's a close-up thermal portrait of the same animal here and a visible light view from a similar angle here.
« Last Edit: February 08, 2018, 01:00:52 pm by Ultrapurple »
The following users thanked this post: bookaboo, frenky
Offline frenkyTopic starter
  • Country: si
    • Frenki.net
« Reply #117 on: October 24, 2017, 07:40:47 am »
That is creazy.  :-+
Offline trump
  • Country: cn
« Reply #118 on: November 04, 2017, 01:33:36 pm »
SEEK Compact XR
Here are two images of my breath. You can tell the breathe-in and breathe-out from my nostril.
The following users thanked this post: SeanB, ThermallyFrigid
Offline Ultrapurple
« Reply #119 on: November 05, 2017, 03:48:42 pm »
LED 'candle' bulb.
Therm-App 384 x 288 camera, ThermApp Plus driver software with 'find edges' enabled. Resized using https://letsenhance.io then slightly cropped.
« Last Edit: February 08, 2018, 01:04:16 pm by Ultrapurple »
« Reply #120 on: November 08, 2017, 09:00:56 am »
Hot off the press, "partly empty" moon.
Lens: 100mm ZnSe lens in place of stock lens.
Lens kluge shown in 3rd image.  :)  Hopefully I'll put together something more solid later on...and get the software adjusted for that lens so I can show temperatures.
Offline Vipitis
  • aspiring thermal photography enthusiast
« Reply #121 on: November 08, 2017, 09:26:15 pm »
whew, those are some nice view for the lens!
I want to request more - using a white hot greyscale palette and locking it. Take a few in rapid succession and stack them in astrophotography software to reduce noise and eventually post process for sharpness.
I am jealous.
« Reply #122 on: November 09, 2017, 01:48:48 am »
I am jealous.
@Vipitis, It could be a while before I can do that.  Although I have seen it discussed on this site, I have never tried the image stacking.  I see there are a few such programs for Linux, though; lxnstack, Siril, Gcx...
It might be best to get the lens calibrated into the software first also.
Offline Ultrapurple
« Reply #123 on: November 09, 2017, 01:48:20 pm »
On the beach in Malta. Probably my favourite thermal image.
Therm-App, 19mm lens, stock app (2014 incarnation - its appearance has changed a bit since then).
« Last Edit: November 21, 2017, 02:43:27 pm by Ultrapurple »
Offline mahony
« Reply #124 on: November 09, 2017, 06:47:11 pm »
A shot of my DIY gimbal after some first testing - the steppers are getting quite warm. ;-)
Camera TE-Q1+ with 36mm f/1.2 FLIR lens.
