On the second and third links, quite frankly this is not how one would image a PCB with the newer focusable Seek Compact models. You would hold the lens a couple inches away and focus it. You would then pull SIGNIFICANTLY more detail out of the Seek than what your pictures show (although a narrower FOV). See attached pics of my Pi with the latest revision Seek Compact.
@Jarrod @IwuzBornanerd I agree that the PCB comparisons where unfair towards the Seek. Worth noticing as I worte in the same post, this was the first Seek Compact camera without any focus capabilities. If the temperature range is high in the image, the Seek's resolution defenitely has it's advantage over the FLIR One. But it requires "sunny" images to bring the noise away. Also worth noticing regarding the seek comarisons, they where shot before Seek upgraded the app alowing to remove image smoothing. Removing it gave a lot more details. But still I think FLIR One's low resoltion (160x120) still gives the same details at close range compared with the Seek Compact.
I use my FLIR One to take images where I want to post analyze the images and uses Seek when the temperature is high enough and it's for the image itself an not the data.
Electric motor shot with Seek Compact (Added FLIR Iron palette to it for comarison)
Same electric motor shot with FLIR One.
I'm adding a few Seek images with quite good details for the resoluion:
Audi V6 engine
Horse. A bit noisy but still sharp
Roof. I think this stands out in details.
One thing I like better with the FLIR is the palette design, especially the iron palette. As I think Seek uses a linear path between the color points, FLIR has a more curved one that makes the red -> purple -> blue -> black transition much softer. For me the Seek iron palette is like draging the contrast leaver to far. This is my opinion on it, but of course others thinks different abot it
Flir iron palette color graph
Image shot with Seek iron palette
Image added FLIR iron palette
I usually takes Seek images with the grayscale palettes so I can add my own palettes later.
