Hello, I own a F1G2 and am on iOS 11.2. It appears that the FLIR camera is detected after unplugging and plugging it back in but no image is shown. It is able to poll the F1G2 battery percentage left. I suspect this is an issue introduced with the iOS update. Prior to this update the application worked without issue. The camera works with the FlirONE application on iOS 11.2 though this application is inferior. Anyone else having problems as well? If so, be warned about the iOS update.
Edit: I've sent Georg an E-Mail via the application support address.
