Ivaylo,
Excellent disassembly
OK, what we have here is a high quality, low distortion lens structure that uses four Germanium lenses. The metal edge is typical of such. Those lens elements are real beauties
That lens assembly would normally cost several thousand Dollars from the OEM.
That front lens element is a very clever profile to meet the needs of a low distortion close focus lens.
Regarding how to handle the lens elements......
The objective is usuall coated with a pretty robust AR coating, sometimes this is a hard carbon coating. The other lens elements also have an AR coating but it is often more fragile and liable to damage if treated roughly or exposed to moisture or humidity for a prolonged period of time.
I suggest not cleaning them with anything except compressed air unless there is a finger print on them, or similar. A dry microfibre spectacles cloth may be gently used on them and a very soft cloth dampened with IPA is also acceptable. Just do not rub with a rough cloth, tissue or with undue force. Treat like a quality coated SLR camera lens and you will be OK.
Fraser
