I have InfraCam and Bcam (2007/2008) and they are internal the same.
The SD Card slot can be activated... if off it stores internal, if on it need a SD Card.
The Bcam has a lower setting for the internal noise generator and more Measurements.
The Kameras are expensive a few years ago. now they are <700$ in used condition.
To name it again, the seek thermal compact xr.
On the paper better than the infracam.
Seek just want to sell and lie about the quality. The XR has 206x156 sensor, this should result give 32136 thermal Pixels but in real each 15th pixel is a hole, because patent.
Additional... the HT-18 uses a Core with the same Sensor like Seek Compact (XR). i belive the A2 is just using a Seek Pro core. If you buy a HTI device you maybe just buy a Seek in another housing.
I connected a Seek XR and the HT-18 works with it, it looks like before, the Seek Pro works not with it.
Better stay by your Infracam... if you remove the housing there is a plastic nose, that limit the angle of the Lens rotation. after removing this, you can get closer to the PCB.
best wishes
joe-c
