It looks to me like a Chinese company that has decided to embrace the FLIR Lepton series of cameras.
From their point of view, the hardest part of the development task has been provided as a 'turn key' solution from FLIR. They then embody the Lepton Core in systems that will serve the market in various novel ways.
They are what the Lepton series need. That is to say, a Chinese manufacturer who is deploying the core in many novel ways. The PCB inspection camera is one, the Thermal borescope is another.
As to the cost of the PCB inspection camera......Hmmmm, I am uncertain what resides inside the units head as the provided link did not work for me. $900 does not seem too extreme to me considering they appear to be a relatively small company producing specialist products using an outsourced FLIR Core. The Lepton is still an expensive component. The FLIR DUO costs £1000 in the UK.
The PCB inspection thermal camera is obviously a specialist item, just like the ETS320. As such, I would expect them to charge a premium. The casing looks to have been well designed but the unit will suffer the same issue as the ETS320...... fixed focus
The use of fixed focus on a PCB inspection camera can be a limitation. Something I am addressing on my ETS320. Sadly modification of the Chinese unit would be more complex as the lens is tiny and it sits behind the FFC flag.
I welcome new and novel uses of the Lepton core by third parties. It is such am amazing piece of miniaturisation that just begs to be integrated into all manner of products. If FLIR ever reduce the unit cost we may see new applications for the core in affordable products.
With regard to making your own PCB inspection camera, this is definitely possible, but the F1G2 would either need a close-up auxiliary lens or it would have to be dismantled and the Lepton lens set to closer focus. The adjustment of the Lepton lens is fiddly, but it would yield a better result than the Auxilary lens.
I have been looking for an affordable Lepton 3 host board that would allow me to use some of the Lepton3 cores that I have from faulty F1G2 cameras. Sadly most are either for the Lepton 2 or else very expensive development boards.
Many thanks to the OP for highlighting this product. Very interesting
Fraser
