Author Topic: RFC: Using PIC24FJ64GA002 as a modern 8042 replacement  (Read 3248 times)
Offline technixTopic starter
  • Country: cn
  • From Shanghai With Love
    • My Untitled Blog
« on: December 01, 2018, 05:45:14 pm »
For a PC/XT clone, the 8042 keyboard controller is a headache, as that is implemented using a microcontroller with a parallel slave port and at least one address line. Most of the 40/44-pin 8-bit PIC has PSP but it lacked that address line, and they are also those bigger variants of the chips.
I then came across PIC24FJ64GA002, a 28-pin PIC24 that has a PSP even in the 28-pin package, and two address lines to go along with that. I wonder if that can make a good 8042 replacement, implementing PS/2 keyboard protocol. Also is there any 5V version of a similar chip?
Offline jazper
Re: RFC: Using PIC24FJ64GA002 as a modern 8042 replacement
« Reply #1 on: December 25, 2018, 08:01:09 am »
You know, you may be able to do this with the venerable atmega328 relatively easily (can handle 5v too)
  • Country: cn
    • My Untitled Blog
« Reply #2 on: December 26, 2018, 03:27:29 pm »
My main processor is a NEC V40HL with a nice overclock on it. ATmega328 isn’t going to be fast enough.
Offline jazper
« Reply #3 on: December 31, 2018, 12:26:17 am »
When you say nice overclock what kind of overclock are we talking? (what speed do you really need?)
Based on this page: http://devster.monkeeh.com/z80/upi42/ it looks like the 8042 was a 12.5mhz chip. The atmega328 can do 16mhz.
Another chip which comes to mind is the STM32F103. It's 5V tolerant but 3.3v so you may need a logic shifter for the output.
The question becomes how much time do you want to invest in it - if you can do it with arduino libraries etc, it'll be quicker to get going.
Online Jacon
« Reply #4 on: January 01, 2019, 11:42:32 am »
...The atmega328 can do 16mhz....
Only in Arduino - actually chip can 20MHz...
  • Country: cn
    • My Untitled Blog
« Reply #5 on: January 02, 2019, 05:40:38 am »
My V40HL is the 16MHz version and I am going to try run it at 20MHz or 24MHz.
Offline Rasz
    • My random blog.
« Reply #6 on: January 02, 2019, 08:28:40 am »
doesnt really matter, keyboard controller is sitting on 7MHz ISA bus, what you need to worry is access timings
READ:
CS, A0 to Data Out Delay 130 ns
tRD RDvto Data Out Delay 130 ns
tDF RDuto Data Float Delay 85 ns
WRITE:
tWW WR Pulse Width 160 ns
tDW Data Setup to WRu 130 ns
8042 handles this with dedicated hardware slave port, what you might need is a small cpld to handle the bus and buffer I/O, or one of those fancy microcontrollers with buildin cpld block, or something with really fast realtime IO like XMOS
« Last Edit: January 02, 2019, 08:32:31 am by Rasz »
  • Country: cn
    • My Untitled Blog
« Reply #7 on: January 02, 2019, 07:37:09 pm »
READ:
WRITE:
That is why I am talking about that PIC24, which also has a similar dedicated hardware slave port. Also since I am overclockiny the main processor to 24MHz, the bus is overclocked too.
Offline Rasz
    • My random blog.
« Reply #8 on: January 02, 2019, 09:01:24 pm »
google... 80 ns, yep, Addressable Parallel Slave Port Mode looks perfect
only if you want it to be, you can configure wait states, default is 3
